โMar-05-2015 02:22 PM
โMar-20-2015 06:18 PM
MagillaGorilla wrote:I guess you are unfamiliar with newer motorhomes that are full of ceramic or porcelain tile. I have looked at many used coaches that show no signs of cracking, and looked closely
Beyond the weight issue is the issue of flex. Ceramic tile does not allow for any flex or any imperfections in the floor. The tiles will crack and lift. For a motorhome you need a flooring that has some flexing abilities. If you do decide to go with ceramic tile, be sure to pick out what you will be replacing it with while your at the store. It will save you a little time down the road. ๐
โMar-20-2015 06:16 PM
soren wrote:I used a flexible grout and adhesive/mortar with good cement board. I guess some don't read others post. No cracking on my MHMagillaGorilla wrote:
If you are going to install the tile following best practices from 1940, you are probably correct. If you understand current technology and use the correct products, not so much. When you get involved with high tech. membranes and synthetic grouts, you would be amazed at how flexible, and durable, installation can be.
โMar-20-2015 01:36 PM
โMar-20-2015 08:27 AM
Goldencrazy wrote:
I have a 2015 Winnebago Sightseer 35G. We don't like the vinyl. Would like to put down porcelain tile. I understand it would add some weight. Wondering if any gas has tile and?or if anyone has added porcelain tile to a gas model.
โMar-20-2015 05:33 AM
โMar-20-2015 04:50 AM
โMar-20-2015 04:00 AM
โMar-07-2015 07:09 PM
โMar-07-2015 03:10 AM
โMar-06-2015 04:13 AM
โMar-06-2015 03:37 AM
โMar-05-2015 08:28 PM
โMar-05-2015 08:19 PM
โMar-05-2015 06:36 PM
