Jan-10-2023 04:55 PM
Jan-20-2023 02:50 PM
David0725 wrote:
I have a 2003 Duch star on a spartan chassis. I figured out the fuel line to the gen set must have a air leak. Or something I have to keep bleeding the gen set. Has anyone ever had with problems and got it fixed? It runs great from a 5 gallon can.
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Jan-16-2023 08:53 AM
TechWriter wrote:I had this same thought I spent hrs trying to fix it without dropping the tank. I had some small dia plastic tubing which was stiff enough to push through, but it could not make the right angle bends. I think the fuel line would be much softer and would tend to bunch up when you push it in. Dropping a near empty tank was not so bad, probably an hr to actually drop it, going to the parts store to buy a new line installing the line, and reinstalling the tank was about a half day when all was said and done.David0725 wrote:
I have a 2003 Duch star on a spartan chassis. I figured out the fuel line to the gen set must have an air leak. Or something I have to keep bleeding the gen set. Has anyone ever had with problems and got it fixed? It runs great from a 5 gallon can.
Have the identical problem. Dropping my fuel tank is the LAST thing I want to do to fix it.
My current "fix" is to detach the fuel line at the generator, connect it to a pump action siphon, and start pumping until I get flow. Then reattach to the generator.
However, I'd like a better more permanent fix before dropping my fuel tank.
So I'm going to try the "catheter" approach. Got this idea during an angiogram when my doctor routed a catheter up my arm vein into my heart. Very slick.
I'm buying a small fuel line to run inside my current fuel line.
We'll see.
Jan-14-2023 08:13 PM
Jan-12-2023 02:31 AM
Jan-11-2023 07:14 PM
Jan-11-2023 05:25 PM
Jan-11-2023 01:13 PM
Jan-11-2023 11:32 AM
Jan-11-2023 08:52 AM
Jan-11-2023 08:00 AM
Jan-11-2023 07:54 AM
