Help me understand how my slide outs work
LaPlaya
I am having slide out issues. Knowing how the slide mechanism works might go a long way in my understanding of why my slide is trying to tear away my vinyl floor. I look under the slide from the outside but it is all enclosed, I don't see any bars, gears, wires .. nothing. A good video on understanding how your slide out works would be most helpful. Thanks. Bill
2001 Fleetwood Flair 31A
11 REPLIES 11
powderman426
If the Lipper slidout info doesn't match what you have, try RBW. They have info on their site about their slisouts. My trailer is five years older than what you have and at that time they used RBW slides.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
wilco
There are several to many different types of slide out mechanisms, some electric, some hydraulic, some mechanical (gears) some cable. It's hard to help with this without knowing what kind of coach you have or what kind of slide mechanism was fitted.
tfw
doxiemom11
Our kitchen/living room slide mechanisms for adjusting are accessible under sections of the kitchen cabinets. I have a cooktop with a cupboard below that contains a drawer. Hubby takes that large drawer out. Next to that is a row of drawers on the right. He also has to take the bottom drawer out there. He is then able to make adjustments.
hooligan
Found a video on slideout.. May give you an idea of how it works. Don't think it exactly addresses your problem.
Slide out repair
The rollers are inside the rv, and normally there are rollers or slides between the slideout and the floor to prevent damage to the carpet or tile..
Notice the slide room goes inside and rides on the rollers, the support for the slide (rails) go under the MH floor. Your gears and motor or hydraulics (mechanics) are under the floor. Adjustments are made at the rails or frame...
Here is video by Lippert on room adjustments...a little hard to follow. This is what the frame under the floor looks like and some of the adjustments.
Lippert slide
Hope it helps
Hooligan U.S. Coast Guard Ret.
2016 THOR Siesta Sprinter 24ST Diesel
2008 SUZUKI Grand Vitara TOAD
1 Pug "Lily", 1 Newfoundland, "George"
1972 MotoGuzzi Eldorado
LaPlaya
It is the dinette slide, kitchen / front slide. The compartments under it are sealed as best as I can tell. I guess I better look at them again more closely to se if there are removable panels in the ceilings on the storage bays.
slemnah
First question is which slide are we talking about? If it is the front slide you should be able to access it from inside the basement compartment. If it is the bedroom, try looking under the bed for all the mechanicals.
conmoto
You made need to put slide slickers or sections of Plexiglas under the slide on the floor when it comes in.
LaPlaya
Executive wrote:
Your mech. should be accessible from INSIDE not outside....Dennis
Are you able to tell me where to start looking inside.
Executive45
LaPlaya
dbbls wrote:
It sounds like you need to adjust the slide. Go to the Lippert home page and look up slides. It will show how to adjust them. Sounds like you need to raise yours up.
This will be good if I have the Lippert System. When I look under the slide from the outside, all I see is a fiberglass or plastic panel covering the whole bottom. I am not seeing any bars, rods, gears, wiring.. nothing, just a plain clean covering and no visible means of removing that panel.
dbbls
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
