Help Tiffin ceiling panels falling down
campingone10
I have 2008 32LA Allegro Tiffin. The Ceiling panels are falling down. Contacted Tiffin service says it has to go back to the factory to be done right? Has anyone had this work done at a dealer on the west coast? History the coach went to Tiffin 4 years ago to replace roof caps water was leaking into coach Tiffin pick up the coach and returned it no charge from Nevada to Alabama. Service guy now says they use furniture glue to hold the panels in place and they must have not used enough and they would add more supports to glue panels. $6600 just to get it to Alabama plus charges to fix problems they made so anyone know of a dealer that has done this work I can trust?
28 REPLIES 28
BobGed
Bruce Brown wrote:
Well...when my parents took theirs to Red Bay the "fixes" didn't last as long as the trip home. It ended up in my garage before it ever made it home. The broken stuff I could fix, the messes caused by Tiffins poor engineering & construction methods I could not.
No one is perfect, and this is an example of an exception to the rule of most Tiffin owner's experience at Red Bay.
2017 Tiffin Phaeton 40QBH
2014 Jeep Cherokee Limited
Bruce_Brown
Moderator
Moderator
MRUSA wrote:
Most dealers can't fix things right, especially major things. That's why folks go back to the factory.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
dougrainer
DELETED
campingone10
Here's some possible irony. Do you still live at the address that Bob Tiffin used in his letter of 4/6/10? If so, you're about five blocks from where I live off of Snowflake Dr.
Yes still live here. I think I have seen your rig parked next to your house nice. Mine is stored indoors over on Arrowhead Dr. Your more than welcome to take a look at it.
2gypsies1
Wow! You surely had problems with that Tiffin. Hope you get it resolved. You should be out with it having fun!!
Full-Timed for 16 Years
.... Back in S&B Again
BobGed
campingone10 wrote:
I also have a site where I have documented some of the original problems motorhomelemon.com
IMHO I don't think that website was the best way to go, but it does indicate there is much more to this situation than has been posted here.
Edit: PM sent
campingone10
campingone10
Repairs last visit.
Oper Description Quantity Unit Price Value
0010 HALL WINDOW LEAKING / REPLACED RU 0.500 H N/A 0.00
HALL WINDOW LEAKING / REPLACED RUBBER AND TESTED
8181 SEAL WDW 1 BLK VINYL 7.000 FT 0.00 0.00
0020 WATER TEST AT BELMONT FOR ROOF CA 1.000 H 0.00 0.00
WATER TEST AT BELMONT FOR ROOF CAP LEAKS / TESTED -NO LEAKS FOUND AT WATER BAY
DURING TEST
0030 RATTLE UNDER DRIVERS SIDE / LUBED 0.500 H N/A 0.00
RATTLE UNDER DRIVERS SIDE / LUBED SUSPENSION BUSHINGS
0040 ENTRANCE STEP NOT WORKING / MAGNE 0.200 H N/A 0.00
ENTRANCE STEP NOT WORKING / MAGNETIC SWITCH BAD / REPLACED MAGNETIC SWITCH
2544 SWI DOOR MAGNETIC CLOUD 1.000 EA 0.00 0.00
WH
0050 STEP MOTOR BROKE / REPLACED 0.500 H N/A 0.00
16684 STEP DBL CNV KIT FOR 1.000 EA 0.00 0.00
903209000 KW
0120 ROOF LEAK / REPLACED CAP RAILS LA 22.000 H 0.00 0.00
ROOF LEAK / REPLACED CAP RAILS LAST SUMMER AT DEALER / REPLACED SKIN
1660 SEAL A/C 14X14 2.000 EA 0.00 0.00
1156 VENT RF 5 BLK VAC-U-JET 1.000 EA 0.00 0.00
5866 ALPHA WH SEALER SELF 2.000 EA 0.00 0.00
LEVELING
28722 SEALANT SIKA 221 AL GRA 20 14.000 EA 0.00 0.00
OZ SAU
5536 ADH SILICONE SELF LEVEL 1.000 EA 0.00 0.00
BRIGHT WH
5535 ADH SILICONE CLR 10.2OZ CSL 1.000 EA 0.00 0.00
616 GUTTER SPOUTS-PW R 1 1.000 EA 0.00 0.00
615 GUTTER SPOUTS-PW L 1 1.000 EA 0.00 0.00
5001578 LOXCREEN 16FT ART BLK SM 16.000 FT 0.00 0.00
CVR
4254 RAIL 20FT ARCTIC WH AWNG 38.000 FT 0.00 0.00
15931 TRML BUTT GEL FILLED INSUL
14 TO
50.000 EA 0.00 0.00
35693 ADH STA PUT SPRAY
POLYSTYRENE FOA
1.000 EA 0.00 0.00
11857 SHT LAUAN 1/4 VINYL FOAM
48X99
3.000 EA 0.00 0.00
7393 ANTENNA AM/FM 1.000 EA 0.00 0.00
7281 CONN ST STL FOR ANTENNA 1.000 EA 0.00 0.00
7358 SPRING ST STL TRUCKERFOR
ANTENNA
1.000 EA 0.00 0.00
7359 CB MNT BRKT ST STL 1.000 EA 0.00 0.00
8025 BRKT TRAVELER 3.000 EA 0.00 0.00
8490 ALG SKLT CVR LARGE 1.000 EA 0.00 0.00
5535 ADH SILICONE CLR 10.2OZ CSL 19.000 EA 0.00 0.00
BRIGHT WH
19.000 EA 0.00 0.00
29926 CAP RF 462X99 1/2 1.000 EA 0.00 0.00
4254 RAIL 20FT ARCTIC WH AWNG 40.000 FT 0.00 0.00
0121 $36.99 ALCOHOL WIPES 1.000 H 0.00 0.00
0130 WATER DAMAGE INTERIOR / WATER ON 14.500 H 0.00 0.00
WATER DAMAGE INTERIOR / WATER ON COUNTER TOPS, IN CARPET, COMING OUT OF LIGHTS AND
DAMAGE TO WALLPAPER ETC / REPAIRED AND REPLACED CEILING AND REPAIRED WALLS AND
TRIMMED OUT / MOISTURE TESTED ALL OF COACH
2254 BATTON CLG PLSTC 99 1.000 EA 0.00 0.00
0150 $920.00 NO CHARGE WORK DONE AT RE 1.000 H 0.00 0.00
$920.00 NO CHARGE WORK DONE AT RED BAY BODY SHOP / LS ROOF RAIL, LS AWNING RAIL, RS ROOF
Terms
Pay immediately w/o deduction
TIFFIN-EMPLOYEE
TAX 0.00
Total Labor 0.00
Total Parts 0.00
Total 0.00
campingone10
Sorry for the confusion my wife has been talking with them. Yes it is Happay Daze in Sacramento. And Phil the Rep suggested Happy Daze. And Wade Tiffin service manager says has to come back to Red Bay if we want it done right. Tiffin is the last one to work on the roof. I will dig for the paper work on the repairs done last time and post later. Thanks
BobGed
campingone10 wrote:
The rails were replaced with aluminum at Rupert's auto body in Carson handled by Tiffin. Then rain was coming in though light fixtures wall panels came loose and Tiffin came and took it back to Red Bay 1 month of repairs to roof and panels inside. We have talked with Phil that suggested Lazy Days in Sacramento for repair. But I also have Wade in service saying no dealer can do it right must come back. I was hoping someone had the work done. I just want it done right.
Okay I'm sorry but I continue to be confused. Phillip is the west coast rep. Wade (Humphres) is Tiffin's warranty manager and is also in charge of the service center in Red Bay. As far as I know, Phillip reports to Wade.
There is not a Lazy Days in Sacramento (they're in Tucson and Tampa). There is a Happy Daze in Sacramento so possibly that is who you are referring to.
Just what work needs to be done? And who do you feel was responsible for the failure? Rupert's or the service center in Red Bay?
In either case, if Tiffin authorized the original repairs under warranty, which have now somehow failed, they would be responsible for covering the necessary work to make it right. You should not have to pay anyone to drive your coach to and from Red Bay, and you definitely shouldn't have to pay for the repairs.
If you could provide more details as to the work that was done and exactly what you're current problems are, either I or someone else here might be able to offer some advice that might help you.
campingone10
When you say 'roof caps' do you mean the radius portions of the roof, with the installation of aluminum roof rails?
Or are you saying the entire roof was replaced by a Tiffin repair center? I'm not saying it's impossible for a repair center to do a complete roof replacement, but I have been a member of the Tiffin forum for almost 8 years, and I never heard of that being done anywhere but at Red Bay.
Could you clarify just what work was done and who did it?
BobGed
campingone10 wrote:
Yes this is a major problem, dealer support has been a disater a Tiffin repair center replaced the original roof and first rain we had water coming through the light fixtures.
I'm a little confused. You say a Tiffin repair center replaced the original roof, however in your first post you said the following:
campingone10 wrote:
โ€ฆโ€ฆHistory the coach went to Tiffin 4 years ago to replace roof caps water was leaking into coachโ€ฆโ€ฆ
campingone10 wrote:
Minor problems they can fix anything major my personal experience is they can't. I would know first 3 summers were lost having this thing repaired. And when Tiffin tells me directly the dealer can't fix this ceiling issue I believe them.
I have had what I would call major repairs done at two west coast Tiffin service centers, and they both did excellent work. This is why I earlier suggested that you call Phillip Hollingsworth. Maybe your particular repair does in fact have to be done at Red Bay, but if there is a facility on the west coast capable of doing it, Phillip would know.
Cloud_Dancer
If ceiling panels have foam insulation, and if they are glued to the roof frame members(trusses) during original assembly, they will droop down if roof has leaked rainwater.
The ceiling foam usually has shelf paper bonded to it, AND this paper is what is glued to the trusses. Whenever it gets wet, the paper looses it's bond to the foam. I have found that the ruined paper has to be removed in glue area, AND special/specific FOAM glue has to be used. The original type of adhesive will NOT work.
Sorry. I used the word roof, where I should've used ceiling. I corrected it, makes sense now.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
campingone10
Because this unit is OUT of warranty by 7 years. Tiffin can fix it cheaper than paying a dealer to do it. Besides, Tiffin owes this customer nothing after 7 years. So, if you need Goodwill, go to the factory where they have the parts available. Doug
Just for the record I purchased this MH new around 2010 so no it's not out of warrantee 7 years. And Tiffin says directly the dealer won't do it right it has to come back to factory. I don't know where you came up with this cost thing. And at no point did I say Tiffin owed me anything or expect it. I posted asking if anyone has had this issue fix outside the factory on the west coast. Seems your goal is to attack anyone with Tiffin problems.
