Jul-28-2013 12:56 PM
Jul-29-2013 04:47 PM
Jul-29-2013 01:57 PM
skipnchar wrote:
With a normally aspirated engine (no turbo or super charger) you will be loosing something like 10% of your horse power for each thousand feet you go above sea level. If you have a turbo diesel or turbo charged gasser, this power loss is almost non existent. Also keep in mind that water (also coolant) will boil at a MUCH lower temperature at high altitude so you MAY have lost some water from your radiator. Check to be certain you have a GOOD radiator cap on your engine to keep the coolant under correct operating pressure.
Jul-29-2013 12:45 PM
Jul-29-2013 11:46 AM
Jul-29-2013 11:34 AM
Jul-29-2013 11:11 AM
wolfe10 wrote:
It takes more breaths of air at 10,000' to supply your body than at sea level!
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Jul-29-2013 10:16 AM
Jul-29-2013 09:43 AM
Jul-29-2013 09:30 AM
wallynm wrote:
I agree and you could change the equation by changing the carb jets based on altitude.nohurry wrote:
Skip, I always enjoy and respect your posts, but that 10% per 1000 ft can't be right can it? That would mean if a N/A engine was running at 7000 feet elevation, it would only have 30% of its power. I know there is some loss, but I have heard figures in the 3% per 1000ft range.
Jul-29-2013 08:48 AM
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
Jul-29-2013 08:15 AM
Jul-29-2013 06:44 AM
Jul-29-2013 06:33 AM
Jul-29-2013 06:04 AM
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) 🙂
