House Battery charging
k7acz
I have a 2006 Jamboree on a 22BCHEV Chassis. Can I keep my house batteries (2 ea type GC2 6 volt) fully charged by having the RV connected to shore power? Does this model have the charger that reverts to a trickle charge when the batteries are fully charged? Reason I'm asking when I checked the batteries the water level was below the plates and now I need to purchase new batteries. Is it safer to use a seperate battery maintainer type charger conncted directly to the battery. I have found several sources for my reeplacement GC2 battery with the removal caps to fill with water but Die Hard has a 6 volt GC2 golf cart battery that does not need to have water added (sealed unit). Does anyone have any experience with these Die Hard batteries? Thank you
12 REPLIES 12
IAMICHABOD
pianotuna wrote:
The WF series are not good. Consider replacement with something else.
I would agree,I would replace it with a Progressive Dynamics unit.
Call Randy at Best Converters They will give you the best one for the replacement.He has helped me and many others on this Forum.
Ask Randy
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
pianotuna
Nomad II
Nomad II
k7acz wrote:
OK, I don't see how I reply to everyones Individual posts so thanks to all who responded. My electrical panel shows Model number WF8914. Yes, I do have the exact same BiRd unit on the side of my battery unit. Your photo looks exactly the same as my Jambroee. I would post a picture but I don't see how I show a picture in my post like you guys. Maybe someone can point me in the right direct. TU agn for your help.
Alan Zack, CWO, USCG, Ret
Regards, Don
IAMICHABOD
Here is a link that will walk you thru photo posting Photo Posting Link
k7acz
AJR
I had a 2003 TT that had most likely the battery charger that is in your 2006/5 unit. I say that because it would boil the water out of the batteries as you described. Dang… The solution is a plug-in gadget on your current charger that makes the charger into a three tier charger that will never hurt the batteries by overcharging. Boiling off the water. It worked very well with golf cart batteries.
Come on you older folks, what is the name of that gadget?
2007 Roadtrek 210 Popular
2015 GMC Terrain AWD
IAMICHABOD
I have a 2006 Tioga on a Chevy chassis also made by Fleetwood.
unless it has been changed out you will have a WFCO converter,these old ones will boil your batteries.You need a newer 3 stage one to replace it.
I replaced mine with one,Like this one I keep it plugged in all the time and check the batteries monthly and very seldom have to add water over the more than 12 years that I have owned it.
Also look in your Battery Bay to see if you have a BIRD like this one,many of the Fleetwood RVs of this era had them,as mine does. When plugged in to will keep all of your batteries including your chassis battery,that is what it is designed to do.
Click For Full-Size Image.
As for the Die Hards my experience with them was not good I would stay with the ones that you can check the water.
bobndot
Yes solar. My 100w panel on my roof keeps my two coach and one chassis battery topped off. I never have to worry about them draining down while parked. I use an mppt controller .
Grit_dog
Nomad III
Nomad III
Yes your rv does or did have a converter/charger.
You should probably verify the old batteries are toast and verify the converter is working before worrying about which brand of battery to buy.
And FLA/SLA or AGM are fine. Since you don’t say whether the die hard battery is sla or agm.
pianotuna
Nomad II
Nomad II
How old were the batteries?
Another option to storage charging is a modest solar charging system.
Regards, Don
CA_Traveler
X2 Also post the float voltage, but you may need new batteries first for a reliable reading.
Is the Die Hard a AGM? They definitely cost more.
2014 Grand Cherokee Overland
Bob
opnspaces
Navigator II
Navigator II
That vintage I would almost guarantee you the charger is not 3 stage. A replacement is probably around $250 try Bestconverter.com
Link I've read a lot of positive reports on this forum about them.
Matt_Colie
K7acz,
If you come back with the make-model some one might tell you to keep or pitch it.
Nobody can answer your question without knowing the make and model of you current converter. I can tell that the coach is old enough that I may not be a very good one and it maybe be worth your while to change it out for a new multi-stage number.
Matt_C
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
