How many engineers required to change a light bulb?
subtroll
We have many reading lamps with 12VDC bayonet bulbs. I'd like to replace the bulbs with new LED bulbs but find it difficult to seat the new bulbs. Its easy to remove old bulbs because the spring ejects them, but the tight clearance around the bulb prevents my fingers from grasping the bulb enough to turn it.
Has anyone come up with a simple tool or aid to push and rotate a new bulb?
2004 National Tropi-cal Sterling 396
2003 Jeep Liberty
13 REPLIES 13
wildmanbaker
They actually make a suction cup with a fin on the back for changing those bulbs. Doug is on a roll!
Wildmanbaker
mtrumpet
Change the bulb? Heck, at a recent RV gathering, it took FIVE of us just to go BUY the bulb! :B
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
subtroll
Thanks for the help. Rubber gloves and patience made a difference and 19 LED lamps are much brighter than the mini 12 VDC incandescent flood lamps.
I think I met the guy that was 450th out of 350.
2003 Jeep Liberty
icechip
old guy wrote:
I agree with the 10 engineers. we had one here in our town who graduated 450th out of a class of 350. he was that bad.
That comment gets me wondering what place some of our doctors finished in their class?
dougrainer
hotbyte wrote:
Not sure but I can tell you how many computer programmers it takes to change a light bulb. None...it is a hardware problem 🙂
WRONG. They would tell YOU to unscrew and reinstall the bulb numerous times and then relocate the lamp to another receptacle, THEN tell you it is a hardware problem and thanks for the credit card payment for the "technical help":B Doug
Busskipper
Just one -- he works for the Government and just buys a new coach if the lights don't work.
JMHO,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
GX470-FMCA - Travel less now - But still love to be on the Road
States traveled in this Coach
hotbyte
2018 Minnie Winnie 24M
Gonzo42
Hey!!! I resemble that remark!
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
old_guy
dougrainer
At least 10 engineers. 9 to argue who has more knowledge on bulb changing and how THEY could have designed it better. The 10th was just out of College and just replaced it. He did not have enough experience to do anything else just yet. Doug
RoyB
I Changed to LED bulbs - heat problem solved here
Not only did they burn my fingers they was causing my lamp fixture lens to turn dark colors as well as the ceiling around the bulb
Roy ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
rgatijnet1
A piece of plastic/rubber tubing may help.
bsinmich
Have you tried rubber gloves? The ones I use when dumping would give a little extra grip on the glass.
1999 Damon Challenger 310 Ford
