โAug-15-2004 01:22 AM
โMay-28-2009 12:09 PM
ALnCORY wrote:
my old 64 GTO would get 18 miles per gallon
โMay-28-2009 08:30 AM
โMay-28-2009 03:41 AM
โMay-27-2009 09:16 PM
Leeann wrote:
And seriously? Not old enough? I had the option to put leaded or unleaded in my first car...that I got when I was 20. The first year I owned the car, unleaded disappeared. Wasn't a problem for my little '81 Honda Accord, but a coworker with a 70s Ford big block was bummed.
โMay-27-2009 08:59 PM
Tioga76 wrote:
Thanks for the advice. I'm glad to hear that I don't need a complete valve job because I don't have the $$ for that this year. I'm curious though... I've heard that using unleaded gas on these old engines can be harmful to the valves. My owners manual says to use leaded gas only, so I add a lead substitute to the gas sometimes but I'm not consistent with it. I'm not old enough to even remember leaded gas - does the use of unleaded harm the engine?:h
Leeann wrote:
The float could be filled with gas; happens to old ones. That would make any adjustment moot.
โMay-27-2009 08:51 PM
โMay-27-2009 08:37 PM
Griff in Fairbanks wrote:
You don't necessarily need to do a complete valve job. (In fact, I'd recommend against it.) Instead, you should be able to simply replace the valve stem seals without removing the heads or the valves. Use compressed air to keep the valves in place and borrow, rent, or buy one of the spring compressors that work with the head still on the engine. That way, you only have to remove the valve covers and don't risk reconditioned valves causing ring blowby.
โMay-27-2009 08:22 PM
Tioga76 wrote:
Is it difficult to repair/replace the valve stem seals? I'm an okay mechanic but I haven't done much in the way of internal engine repairs.
I had the float adjusted correctly last summer and I haven't driven it much since then. Never hurts to check though.
โMay-27-2009 08:06 PM
Leeann wrote:
Valve stem seals.
Have you checked the float level on the carb?
โMay-27-2009 08:02 PM
โMay-27-2009 07:17 PM
โMay-27-2009 06:45 PM
โMay-27-2009 12:35 PM
โMay-27-2009 12:00 PM
