If you have "dealer"...
That York is enough load to make a 460 hold back at idle. It also reduces MPG noticeably. Ours had a long single V-belt and we found that only top-quality belts like NAPA, Dayton, Gates, etc would last more than a few hundred miles.
It was when I tried to charge to normal low side spec with 134 that I found the high side pressure was climbing to over 300PSI and making the compressor balk, causing the belt or clutch to slip. I'd shift to N for traffic lights on hot days. For a fall "autumn leaves colors" trip, I took the belt OFF and gained nearly an MPG. When you go from 7 to 8, that's a lot.
I'd say try to leak test it. Ours chafed through a hose that was attached to the back side of the radiator shroud. The "dealer" installs are so sloppy that there are more opportunities for thins to rub on sharp edges than you get on "factory."
If you want, you can make a nice conversion with a Sankyo axial compressor. I say that one because it's available with mounts to replace York (an aluminum compressor) and Tecumseh (same thing in iron). You can also get a large parallel flow condenser, drier, TXV, and custom hoses to put it all together without hose clamps. I can send sources, but I'd guess that since the time I looked at it, the parts/supplies cost would be around $600, you providing all the labor. Go Axial and I don't think A/C would decrease your MPG by any amount you could measure.
Of course you can fab your own A-Dapter Kit for a Nippondenso compressor if you have one of those around and somebody who can fab it. I junked a perfectly good 6P148A by mistake thinking it was one of the junk FS6's I had. Then I really kicked myself when I realized I could have used it to replace the York.
