is 11 y/o original spare still a spare?
burlmart
or do most replace w/ new tire w/ each new set of tires?
2005 Trail Lite 213 B-Plus w/ 6.0 Chevy
25 REPLIES 25
Bordercollie
I may be wrong but think that tires on an RV sitting parked for months at a time don't get the "lubricants" in the rubber circulated plus the sun attacks the rubber starting sidewall cracks. The ten year old original spare, or one taken off the rig after 5 years as a spare, should be OK to get you to the tire store but keep your speed down and listen for any thumping sounds that may signal tire coming apart.
dewey02
Well, your spare tire is probably not as bad as "The Old Man's" spare tires in The Christmas Story movie. "My old man's spare tires were only tires in the academic sense. They were round, they had once been made of rubber."
https://youtu.be/JwF4qieecEM?t=37
burlmart
all good answers.
we mostly stay close to home. new 6 michelin are LT225/75/R16 LTX M/S2 115R RBL
i am kinda leaning to replace it as a matter of peace of mind and convenience.
convenience wise, after roadside puts spare on, i need to have it taken back off and replace w/ new or patched flat (can they even do that on these hi pressure tires?) but if i had a spare that matches other 6 michelins, i only need to take flat tire in our car to be made into new spare, and then bolt it onto rear of RV.
glkids2
If you are going on a cross country venture I would definitely replace. Call it peace of mind. If you are staying local I (me) would roll the dice. But that's just me
mgirardo
If it wasn't exposed to the elements for those 11 years, I would continue to use it as a spare.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Cobra21
JNorton wrote:
In 2010 my 98 Gulf Stream 22' blew a tire outside of Joplin Mo. Used the original spare to drive the 170 miles to my sisters in Ozark Ak. Then replaced the tire. If a spare is used just in a pinch I don't see the problem. I definitely would not use a 12 year old tire in normal service. It was a covered spare on the back bumper with no signs of cracks.
My feelings as well. A spare is a spare. Some people don't even have a spare!
JNorton
2008 Fleetwood Tioga Ranger 31W E450 V10
burlmart
it has never come off its rear wall bracket. it has a white vinyl cover and looks like new. but i know it is a different story internally.
i have 6 new michelins.
time2roll
My truck spare is 15 years old. I would not hesitate to use it to get to a tire store in a pinch.
I replaced my trailer spare twice as the tires on the road were all defective.
If these MAXXIS age out with no issue I plan to keep the spare indefinitely.
j-d
11-YOA is no good. Probably worse unused for the 11 then put on the road, than if it'd been run some.
I've only bought new tires twice, in both cases bought seven, and rotated the spare with the two fronts. That way I get some use out of the spare, possibly even up the tire wear, and don't have issues around the custom valve stems on the rears.
Ford doesn't recommend rotation of the rear duals.
EDIT: Oh, the spare I recently replaced had never seen pavement. 12-YOA and still had mold marks on the tread.
darsben
11 year old spare is most likely only good for an anchor.
HOW WAS IT STORED AND MAINTAINED
Traveling with my best friend my wife!
