โNov-16-2015 09:56 AM
โNov-17-2015 05:19 AM
Executive wrote:
Obviously the ReadyBrake was NOT hooked up correctly. The ReadyBrake cable attaches to the FRAME of the towed vehicle and to the FRAME of the towing vehicle. If the towed vehicle becomes separated from the towing vehicle the small aluminum spacer snaps and the towed vehicle stops in it's tracks. I would say it's operator error that allowed the two vehicles to come together. Insurance is the only way to go....Dennis
โNov-17-2015 02:53 AM
holstein13 wrote:Executive wrote:I've always wondered about this. Are you sure that all Ready Brake systems have this? The only reason I ask is because Ready Brake sells a supplementary break away package called the ready stop.
According to the website, "This device will set and hold the brakes on your towed vehicle in the event it should ever become separated from your RV while in motion." Maybe the OP doesn't have this add-on.
Looking at the diagram on the Ready Stop page, I'm not even sure it would have worked in this situation.
โNov-17-2015 02:38 AM
โNov-16-2015 11:00 PM
โNov-16-2015 10:14 PM
lacofdfireman wrote:I have had the lock not work on that type of pin, Lost the lock somewhere between Whitehorse and Chicken Alaska and the only reason it didn't fall out was because of the safety cable holding the pin in on a Blueox towbar. checked the other one and found it full of grime from the road, no cover to keep the **** out and every time I hooked or unhook it pushed more garbage into the lock.DownTheAvenue wrote:lacofdfireman wrote:
...50 miles into the trip I hear a clank and I look over at the Backup monitor and see sparks flying all over the tow vehicle.... The receiver either broke the Hitch Pin or it came unlatched somehow. I now for a fact that it was put in right as I checked it twice. Weird thing is before we left I had looked at this extra hitch pin sitting on my garage floor like 4 different times as I passed it loading stuff into the Motorhome and on the last one I thought I should just throw this in with my tools.
First I am so glad the incident was no more serious than it was. It could have ended so much worse, as you know. Having said that, you should not be so certain that everything was correctly pinned up. Where did that extra pin on the garage floor come from? I bet it was left uninstalled somewhere in the set up.
You would be very wise to take pictures of the correct set up and make a check list to use every time you hook up.
Thanks for the advise. Not that I don't appreciate it but there was "NOTHING" left out of my setup. The extra pin was from the many receiver hitches that I have. I tow boats, enclosed trailers, flatbeds etc with my Truck and Motorhome and have never had an incident. There are only 2 possible reasons this came unhitched.
1. The pin broke (Not likely)
2. The locking mechanism on the pin failed (Most likely).
There is no possible way I left something out of the hitch system. Zero. I'm thinking the locking mechanism on the pin was the problem... But I have no way to find that out as it was not around after the incident. I could not have driven over 50 miles up and down hills, around corners over speed bumps, etc with no pin in for 50 + miles.
This is the style of pin I was using...
โNov-16-2015 08:05 PM
โNov-16-2015 06:45 PM
โNov-16-2015 06:15 PM
hershey wrote:
You have a lot of damage. Thats what you pay the insurance company for year after year. Call em.
โNov-16-2015 06:09 PM
โNov-16-2015 04:53 PM
โNov-16-2015 04:42 PM
โNov-16-2015 02:23 PM
โNov-16-2015 12:19 PM
โNov-16-2015 12:13 PM
Gjac wrote:lacofdfireman wrote:Maybe I still don't understand what exactly happened but doesn't the hitch pin go through the Ready Break, and wasn't the hitch pin supplied by Ready Break which either broke or came loose?Gjac wrote:
In addition to what others have said I would call the Towbar company and let them know what happened if you hooked it up correctly I would think they have some responsibility in correcting the situation. Also check with your insurance company and see if you have in your policy a vanishing deductible. I was camping with my friend last week and his motorhome rolled forward into his trees in front and he thought he had $1000 deductible which he did but over time it went to zero when he had no accidents. The Insurance company will now cover the entire damage with no cost to him.
Wasn't the Towbars fault. As you can see the entire receiver came out of the Motorhome and the tow bar etc was still attached to the jeep...
โNov-16-2015 11:46 AM
Having never made a claim before I'm wondering if I get an estimate does the insurance company write you a check or do they write a check to the repair facility? What I'm getting at is maybe the jeep part I can fix myself cheaper than the repair shop. That way if there was extra money it didn't cost me I could apply it to my deductible? Not sure if that's how it works though. Maybe that's not an option. The RV for sure I cannot repair. But the Jeep I probably can.
