Issues with Toad Pigtail
ncrowley
The connector between the coach and the toad worked loose so we reattached everything. We checked the continuity and it all looks good. However, the right turn signal is not working. Everything else is. Are there any hints about what we should look for?
Nancy
Newmar Northern Star
15 REPLIES 15
xctraveler
Not sure which connector you mean. Was it the pigtail that came loose from the socket or did the socket come of the coach or car? After trying most everything in my history I have resolved this twice by opening the connectors on the ends of the pigtail and securing them and then either wrapping them with electrical tape (not much room to do a good job) or potting them in silicon so they cannot short. I secure the plug at the tow'd by using a velcro strip from the cord to the tow adapter. This reduces the pressure on the connection and prevents the socket from dragging on the road and being destroyed.
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
chastho
On my Freightliner chassis the fuse is the left rear compartment with the 50 amp cord. It is in a small black box with a black and grey wires going in the top of it There is a fuse for the right and left tail/ brake lights.
YC_1
ncrowley wrote:
Thanks for all your inputs. The right light works with headlights and brake lights and the lights on the coach work. Doesn't that mean the fuse should be fine? We will try the prying open the pins and spraying with contact cleaner.
No. There are often separate fuses for the toad wires.
If you don't grab a meter or test light you are just grasping at straws. I especially recommend a test light working on lights because a voltmeter can fool you with a poor connection.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Mandalay_Parr
Probably each wire going to the toad is fused located in a rear compartment.
Jerry Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
TexasH
Johno02 wrote:
We spray the connectors with electronic contact cleaner regularly. Seems to work for us.
2002 Southwind 37U Ford F53 - V10
2007 Jeep Liberty Toad
tropical36
Sounds as though you have and can use a meter, so firstly, is there intermittent voltage present at the receptacle on the coach for the R turn signal, before blaming it all on the umbilical cord? I assume that the R 4way is out as well?
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
ncrowley
Nancy
rockhillmanor
T bone wrote:
Go ahead and check the bulb,this is a prime opportunity for it to have burned out!!!!Murphys Law!!!
x2
I've hunted down wire problems several times until I found out it was
just the tail light bulb connection just get corroded. These new bulb connections aren't your old 1157 screw in bulbs. Pull it out wipe it down and stick it back in and it will light before you start hunting down wires.
imgoin4it
I think Newmar uses relays for power to the two flights. If so you can probably find them in the passenger side compartment next to the rear wheels. It is a small electrical box and the relays are small square black plug with two pins. They are interchangeable so you can unplug one for the left light and try it in the other. This assumes you have a Sparten chassis and that this is the problem. If it is your problem you will probably have to order one from Spartan.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
YC_1
Sounds like a blown fuse on the RV. If wires were loose it is almost certain.
test light
Everyone should have one of these test lights. You can buy them at any automotive store. The diagram for the wiring are available online.
Wiring diagrams
H/R Endeavor 2008
BTPO1
I would start by checking for voltage at the connector. If there is no voltage there, I would check the fuse for the right side of the TV. If the brake and tail lights on the right side are not working then I would check the ground on that light. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
T_bone1
2017 Georgetown 329S
2015 Toyota Tacoma toad
Johno02
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Mandalay_Parr
Might check the fuse. Mine located in rear compartment. I blew one once.
Jerry Parr
Full-time
2005 Mandalay 40B
2004 CR-V Toad
jrparr@att.net
602-321-8141
Kenwood Radios
