โNov-05-2016 04:04 AM
โNov-06-2016 04:48 AM
โNov-06-2016 04:46 AM
โNov-06-2016 04:18 AM
pslocum wrote:
The handeling complaints I see are simply that people are not used the driving a vehicle of that size with a higher center of gravity. I've driven truck most of my life and can honestly say the f53 handles very nicely. To be fair when it's windy out it is less fun to drive but I do not blame the chassis for that you can add modifications or change swaybar settings to make it a little stiffer but the reality is that if folks sit back and drive the vehicle enough to relax (loose the white nuckle syndrome) they will find that the precived chassis problem was more more inexperience and nervousness than it was an equipment problem. I taught many folks to drive truck,and I found that it took about 25hr behind the wheel for them to relax enough to actually hear what I was telling them. After another 10hr they started doing quite well. (Talk about riding in the hot seat)?? IMHO
โNov-06-2016 02:50 AM
โNov-05-2016 06:46 PM
irishtom29 wrote:
I wonder if some of the reported handling problems are because of too short wheelbases with long overhangs or with the chassis being overloaded by the manufacturer (or both); problems not so much with Ford but with the RV maker. My 34' RV is on a 24K chassis with a 228" wheelbase and it drives OK. I see that some gasser RVs of the same length have a 208" wheelbase and a lighter duty chassis.
โNov-05-2016 06:09 PM
โNov-05-2016 04:20 PM
โNov-05-2016 03:05 PM
โNov-05-2016 02:44 PM
pslocum wrote:DW and I have been driving E150s for over 30 years. Although a much smaller and lighter vehicle than an E450 Class C or an F53 Class A, it dies drive different.
...if folks sit back and drive the vehicle enough to relax (loose the white nuckle syndrome) they will find that the precived chassis problem was more more inexperience and nervousness than it was an equipment problem.
โNov-05-2016 10:44 AM
โNov-05-2016 10:22 AM
โNov-05-2016 08:28 AM
cjoseph wrote:
They only recent problems I have seen posted are:
1. The bolts on the rear sway bar brackets aren't tight enough from the factory and work loose or even fall off. If you have handling problems, check that first.
2. The brake light and ABS light come on in some of the 2016 or newer models. Ford has a TSB for a re-flash that fixes it.
Other than that, like said --bullet proof.
โNov-05-2016 07:50 AM
โNov-05-2016 07:24 AM
โNov-05-2016 07:18 AM
