Just got my first Class A
glockgeek
I had a crown victoria p71 and just for the heck of it I posted it on Craigslist up for trade and I got response about this motorhome...
Well to sum it up... I got a Class A now!!
It is a 1982 Allegro 30ft 454 gas. It has 39,205 miles on it now after the drive home.. It has a 6500 watt onan gen with 200 hours. And EVERYTHING works as new!
Merry Christmas
30 REPLIES 30
Jarlaxle
glockgeek wrote:
Oops sorry guys I was wrong...
She is a 1982
A little older but still a pretty girl..IMO
I looked at the title and I found the correct info
It might be a 1983 coach on a 1982 chassis...VERY common, if so.
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. 😞
Current rig:
1992 International Genesis school bus conversion
07blacktruck
glockgeek wrote:
BigRabbitMan wrote:
I would like to see it as I also have an older coach.
Yep sorry... I changed the name on photobucket to 1982 Allegro from 1983 and it messed up my links...
should be fixed now
@falconbrother.... thanks a bunch... I will get right on it! 🙂
X2 on what BigRabbitMan says.
Big fan of the older models and always looking for info on rebuilds and people just using them. The new ones look great and I would love to have one but I don't think they have the character of the older models and I'm pretty sure the price would keep me from just enjoying it so much. I won't admit to having been lurking here of late, more likely just to not having been around the forum for awhile. With that being said, I remain on my quest to find other owners of the classics and see how and what they are doing with them.
Stay safe out there...
Ken
The inherent vice of capitalism is the unequal sharing of blessings;
the inherent virtue of socialism is the equal sharing of miseries. Winston Churchill
glockgeek
BigRabbitMan wrote:
Somehow, the links provided in the above posts just take me to the main Photobucket page and not to the photos of the coach. I would like to see it as I also have an older coach.
should be fixed now
BigRabbitMan
The above is an excellent post regarding the care and feeding of an older coach. With frequent service (very inexpensive to do)and timely repair, you will have a very reliable and fun coach that will go anywhere.
BigRabbitMan
Gas to Diesel Conversion project
76 FMC #1046, Gas Pusher became a Diesel Pusher
Discussion thread on this site
"You're never too old to learn something stupid."
falconbrother
The GM Chassis should serve you well. The 454 is a powerful engine. I have the TBI (7.4)454 with a turbo 400 transmission (1990 P-30). I have no complaints. I would suggest that you pick up a spare set of plug wires, rotor button and cap. Those occasionally fail to one degree or another. It's an easy fix but, only if you have the parts. I just keep the spares on board so, when I need them I'll have them. In a lot of the older P30 chassis the right front brake line needs to be replaced. Mine was replaced by a previous owner. Apparently they fail on the inside and cause that front right caliper to fail to release. It's an easy and cheap fix. Keep an eye on that master cylinder which is located under the driver's seat area. You'll see it when you open the dog house engine cover. If you need to replace the master cylinder it's an easy job and cheap. I replaced mine two years ago with a rebuilt unit from Advance Auto parts. After the core exchange it cost me like, $17.00 bucks for the part.
Someone else mentioned it and I'll say it again. Check your tires for age. Don't risk driving on old tires. It's not worth it. My OEM tires were D rated 16-7.50 or something like that. I replaced them (after a bad blowout) with 16-215s. I don't remember the exact specs but they are 215s and "E" rated, American made Coopers, made in Arkansas. They ride real nice.
I flush my radiator every two years and my old 454 runs nice and cool. Unless you know the status of your radiator I would suggest that you consider a real good flush. I did a lot of reading and chose regular old radiator flush solution from Auto Zone and I filled and flushed three times. It's an easy job that makes that big engine run nice and cool.
Change out your fuel filter. It's cheap. Heck, they sell the filter at Walmart (Fram). It's a little filter considering the amount of fuel it handles. Mine is located on the inside of the frame rail, right side, about halfway back, behind the steps. Changing the filter will make life easier on your fuel pump.
Check your roof over real good. If it's a rubber roof, and hasn't been recovered it almost certainly needs attention. If it's a metal roof they are super easy to work on. The EPDM rubber is too but, make sure to use only EPDM rubber compatible sealants, etc.. They sell that stuff at camping World.
The front end on the older P-30s have a bunch of lube points. I lube mine every few thousand miles. It's easy but messy. Check for zerk fittings on the drive shaft too (at the universal joints).
Take a drive to the coast and have a great time. We camp at the coast a lot. I love it. We never want to come home. We probably spend six weeks, or more, at the beach every year.
BigRabbitMan
BigRabbitMan
glockgeek
She is a 1982
dcbrewer
Congrats, very nice, now have some fun and enjoy!!!
H.B.
07blacktruck
Not sure how you made that trade but you did good. That is a classy looking coach. Those older Allegros were some fine looking machines. Glad to see you with that and planning ti use it instead of it getting trashed. I've got an 89 Elandan and I think the older coaches had way more character than the newer ones. Keep us all posted on what you are doing with it and to it.
Thanks for sharing.
Ken
glockgeek
Bob & Ann wrote:
What a nice find. It looks like new and will give you many years of fun and service. You might should check all of the rubber hoses, belts etc. Also the tires need to be seven years old or less. I see that you live in Alabama. If you need anything repaired professionally you can have it done at the plant in Red Bay. If you need any questions answered just give them a call and they will be more then helpful. They are also a great source for original replacement coach parts.
Congratulations and enjoy!!!!!!!!!!!!!!!!
It has new belts and hoses.... As far as tires I have not checked... It has been 30 degrees here and its way to cold for me to do too much outside... I am a southern boy and hate winter...
AllegroD
Very sweet!!
Bob___Ann
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
sunkist
Congratulations! She looks sweet! I once owned a class A for a couple hrs. Long story but on the drive home from purchasing, it overheated. Head gaskets our or worse, I never bothered to find out. Scared me so bad I took it back. Never bought another one!
Sunkist
'05 Chevy 2500HD crewcab 4x4, 6.0, 4:10 posi
'97 Roughneck by Lowe. 17' Walleye slaying machine
'07 HD Ultra
:("Too many toys, too little time":W
Boonedocks
Good Looking unit!
2003 Country Coach Intrigue towing 2006 Ford Focus. Follow our full timing adventures at The BooneDocks
