KING REPLACEMENT HD ANTENNA
Fleetwood_Coupl
Has anyone else replaced their wine-guard windup antenna with one of these. It says something about power, mine dosen't have power going to it so how would i pull this off.
http://www.campingworld.com/shopping/item/king-digital-hdtv-antenna-replacement-head/68415
2006 Fleetwood Expedition 38n
300 Cat Engine (MP-8 Performance Module)
Retired US Navy SCPO
24 REPLIES 24
lacofdfireman
I'm getting ready to replace my batwing with a King. I can't stand the sound of it chattering going down the road. Super annoying. I never use it anyways.
2007 Forest River Georgetown 350 DS SE Bunk Model Class A V10
2013 Yamaha Super Tenere 1200 ADV Bike
MotoJug Motorcycle Hydration System
Fleetwood_Coupl
Oldgrape wrote:
I'll have to double check it. The box looks exactly like the picture you posted Senior Chief. ๐Ÿ™‚
if the fuse is fine you might need to cycle the switches a few times. I get that same thing on my TV if I forget to switch from the DVD back to ANT maybe yours is sticking.
Dutch_12078
As I recall, the "BOMB" (Box Of Many Buttons) pictured turns the 12-VDC power to the antenna on when you select "ANT" as the signal source. Any other choice turns it off.
Dutch
2001 GBM Landau 34' Class A
Oldgrape
Galen & Amy
2006 Winnebago TOUR 40KD
Joined 06/2014
USN Retired
Fleetwood_Coupl
There is a 3 amp fuse behind mine. I have no switch either I think it' powered by that box.
Fleetwood_Coupl
Oldgrape wrote:
Good info. I do have a question about my system. It is the Winegard Batwing with the additional attachment. It supposedly receives its power from the black switch box which is always on (no on/off switch). I'm lucky to get two channels in town on the front TV. The rear TV and outside TV gets a message on screen saying signal TOO week. Is that the antenna or maybe the switch box not really getting and providing 12VDC?
is your black box like this one.
jorbill2or
I would say It's not getting 12 volt power somehow . if there is no switch and it's "on all the time" it doesn't make sense there must be a switch somewhere otherwise your cable reception would be all messed up
Bill
Oldgrape
Galen & Amy
Joined 06/2014
USN Retired
VTR
Just put a king on last week or so. Went from 22 channels (batwing) to 39 channels in the city. Most of the new ones are spanish speaking stations! We will see if it helps on the road or not. Easy swap out, looks nifty too.
rgatijnet1
JNorton wrote:
No antenna receives HD unless it is being transmitted.
That is sort of a DOH. :S
Since HDTV is being transmitted and the OP wants an antenna to receive it, who cares what you call it? I know some of the HAMS are fanatical about antennas and always correct everything that anyone else says about an RV antenna, but who cares about the terminology. The OP, and MOST everyone else only wants to receive a signal which, as you say, a piece of wire will work. The King works better than a wire. :R
Dale_Traveling
I replace the bat wing with a jack antenna a few years ago. Cracked the amplifier housing and the amp got wet allowing the magic smoke out. No new channels I never saw before but the jack doesn't appear to be as directional sensitive as the bat wing. I'm not having to re-aim the antenna as much after changing channels. Also the jack has an LED on the bottom of the antenna so I can see that the amplifier has power easily. I only got the antenna head piece that working with the crank up bat wing rig which only set me back about $40 or so.
2006 Hurricane 31D built on a 2006 Ford F53
JNorton
You can use a piece of wire for an antenna and it will receive HD if the TV station is transmitting HD. No antenna receives HD unless it is being transmitted ie no such thing as a HD antenna.
2008 Fleetwood Tioga Ranger 31W E450 V10
rgatijnet1
rk911 wrote:
and just so you know, there is no such thing as an "HD" antenna. that's pure snake oil.
I believe the ad says that the antenna is for HDTV, which it is. You can receive certain channels that are broadcasting HDTV network programing, which is probably what the OP is trying to do.
tommy_g
AMEN! AMEN!! AMEN!! I am glad someone finally said it!! Did I remember to say amen?
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
