โAug-25-2015 08:48 PM
โAug-29-2015 06:45 AM
โAug-27-2015 01:52 PM
imgoin4it wrote:
Your 2x12's will probably crack about the first time you use them. Two under each jack, if they are placed so that the wood grain of the two run opposite directions, will help prevent breaking them. I put plywood on both sides of mine and used gorilla glue and screws to prevent cracking them. Heavy but durable.
โAug-27-2015 11:40 AM
โAug-27-2015 08:35 AM
โAug-27-2015 08:23 AM
wallynm wrote:
Read your manual as some brands tell you jacks down level first and then slides out and other brands tell you slides out and then jacks down and level.
Lots of post will tell you to always have jacks down and level before slides out but they have not look in the manuals that came with the coach.TRUST ME
โAug-27-2015 08:04 AM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โAug-27-2015 05:12 AM
โAug-26-2015 10:09 PM
AllegroD wrote:
I always put down a pad. The only time I feel I may not need it is on concrete. All other surfaces are softer and I want the wider weight distribution under my levelers. If I have to drive up on blocks, I add blocks under the levelers.
โAug-26-2015 10:04 PM
โAug-26-2015 06:46 AM
FIRE UP wrote:
...Leveling a coach, almost no matter what size/length/slides/no slides etc. sometimes, requires thought. And, sometimes, it's no brainer. I have always advocated to level your coach, using the tires and wheels, by driving up on, whatever type of lumber you carry. That could be home made ramps, blocks, stacks of plywood etc. If you do it that way, then you're not stressing various parts of the coach, by trying to make the jacks over work themselves and, possibly torqueing the frame/body etc.
Once you're "somewhat" level with your drive-on setup, then, I use the jacks to "fine tune" the leveling. And, if I've driven up on some blocks/ramps to help primary leveling operations, then I break out the blocks for the jacks. That way, they don't have to travel so far to help with the leveling and, stabilization. The farther they travel out, the more lateral movement they will have tendency to display.
And, by utilizing lumber and driving up on it, you get the stability of 6 tires on the ground and, also all four jacks too. This is just my thoughts on how it's done. Many will differ. No biggie.
Scott
โAug-26-2015 06:20 AM
zach477 wrote:
What are some Do's and Don'ts for a newbie to be aware of. What surfaces to put (or not" put them down on? Or any thing else you think of, or mistakes you've made.
โAug-26-2015 05:30 AM
โAug-26-2015 04:26 AM
โAug-26-2015 03:30 AM
WyoTraveler wrote:Reading the literature is your first homework assignment. The jacks will be interlocked with various chassis functions such as engine running, e-Brake on and such. Know what you presets are and the sequence of operation the coach builder recommends. Level then extend or extend then level. Same for when it's time to break camp.
You may want to read your manual about operation of slides and jacks.
