Something I haven't been able to figure out... Is there something inherently bad about scissor jacks that make them not good for lifting an RV for leveling it?
Disclaimer: If I am ever going
underneath my RV I always have multiple jacks and jack stands just in case for safety, and I suggest you do so also. This discussion is only as it pertains to leveling/lifting an RV with scissor jacks when at a campsite.
Many many many people will be quick to say, "scissor jacks are for stabilizing and not for jacking up your RV", but can you explain WHY?? People read that on the internet somewhere and then they are quick to regurgitate it without a real reason why.
Think about it for a minute....MOST regular cars (not RVs) come with a
scissor jack for what?? For jacking up your regular car to replace a flat tire if needed. The scissor jack lifts up your regular car. Lifting is what a scissor jack is designed to do.
I would argue that your RV doesn't know
WHAT KIND of jack you are using....scissor jack, bottle jack, floor jack, etc. Seems like the two main considerations would be 1)What weight limit is the jack rated at, and 2)Where are you jacking it up? For example, I routinely use a 12-ton bottle jack on my axle to jack up one rear side of my 30' Class C RV if I need to remove a tire. I'm pretty sure the RV would not care one bit if I used a properly weight rated scissor jack and lifted it from the same exact spot. Right? (Side note: This assumes you have proper contact and things don't slip while jacked up. Using the flat top of a scissor jack probably wouldn't be a good idea on a round axle jack location, but if the scissor jack were used on the flat portion of the frame AND bolted to the frame slipping would not be a worry.) My point is that a scissor jack that is rated to lift 9000lbs can lift the weight of half of the rear of my RV which is ~4500lbs.
AS LONG AS you are using a scissor jack that is
weight rated to lift a side of your RV, can anyone explain what is wrong with using a scissor jack?? For example, my rear axle weight is about 9000lbs (total). Let's assume it is evenly distributed so that means 4500lbs on each side. If I use a scissor jack on one side and that scissor jack is weight rated for 9000lbs (double the weight of one side of my RV) what is the problem?
I *DO* see a potential problem with using a jack (
ANY type of jack) to level your RV by lifting it AT THE WRONG LOCATION, where maybe you could bend the frame for example. BUT that seems like it would have nothing to do with using a
scissor jack per se as you would have the same problem if you used a bottle jack or floor jack in an improper jacking location. Right??
One last example to prove my point.... A Class C RV DOES have 4 100% proper jack locations that we know about. Let's assume those 4 locations are on the front and rear axles right near the respective tires. Would you agree that it would be okay and do no damage to use 4 properly weight rated bottle jacks (or jack stands), one on each of those jack points to level your RV at a camping site? (Note: I wouldn't actually do this, but I'm trying to prove a point.) If you agree that no damage would happen in this scenario, then how about if the jacks were replaced with floor jacks that were properly weight rated. Any issue? I think not. Well what if those jacks were replaced with properly weight rated scissor jacks. Any issue? I think not.
If this thinking is correct, then would it be right to say that using scissor jacks to level your RV is ok as long as you use scissor jacks that are weight rated properly (I like to use 2x the actual load it is lifting) AND you are using a proper jack location? If so, it gets back to my previous question above regarding Where on the frame is it okay to jack up the RV (from an "I don't want to bend the frame or do any damage because of improper jack location" perspective)?
Ah.....I just thought of one other issue, and maybe this is the reason people say not to use jacks to level your RV, but I don't think I've read it anywhere before... I will wait for a bit to post the issue as I am curious to hear feedback on the above.
-Chris
PS: Have you ever seen an RV being worked on at a repair shop with a jack stand underneath the 4 jack points by each tire? I have. Doesn't seem to bother them.
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
