Looking for Fishing Pole Storage Soulutions
Fleetwood_Coupl
I am trying to figure out the best way to store my fishing rods while keeping the reels on. I was going try some wide Velcro strips across the underside(top) of the long section of one of basement compartments. But even after cleaning with alcohol i cant get it to stick(self adhesive back) Would it be a bad idea to drill holes or use self tapping screws in the top of the basement?
2006 Fleetwood Expedition 38n
300 Cat Engine (MP-8 Performance Module)
Retired US Navy SCPO
25 REPLIES 25
hardint
Truly sweet storage bays !!! My hats off to you.
Fleetwood_Coupl
Thanks for letting me know. I hate that look from big box employees when they have no idea what I am talking about.
FIRE_UP
Fleetwood Couple wrote:
Thanks Scott, I am working in my big compartment that is part of the slide so no issues with tanks or other issues. I was ablable.to locate 2 aluminum tubes but there only an inch wide and to far apart to reasonable use for the intended purpose. I will look into the Rivnuts hopefully HD or lowes carries them.
Fleetwood Couple,
You won't find Rivnuts or, "Nutserts" at Lowes or Home Depot. They are a specialty fastener and, require a special tool to install them. Harbor Freight has them but, they are, as normal, CHEAP! But, will most likely work. The one I have is called a Huck and it's hydraulic. It normally runs anywhere from $175.00 - $275.00, depending on where and when you buy it. The nutserts I use are steel, not aluminum. The Harbor Freight version has a seriously hard time compressing the steel ones.
The principle of the nutsert is exactly like a rivet. A hole is drilled and, the rivet is inserted into the tip of the gun and, pressed into the hole. You then squeeze the trigger until the rivet snaps. In the use of a nutsert, again a hole is drilled, only much larger than what would be drilled for a rivet, and, the nutsert is THREADED onto a mandrel at the tip of the gun. It is then pushed into the hole and, you squeeze the trigger, more than once, until you think the backside of the nutsert is compressed enough to "clamp" both sides of the metal you're attaching it to.
Then, the mandrel is threaded out of the nutsert and, vuaaaaaaaala, you have a machine thread (nut) ready to accept a machine screw that will hold a bracket/clamp/shelf etc. to a wall. That method is seriously stronger and more reliable than just using sheet metal screws or, tek screws (self drilling screws).
But, it's a bit more costly than using the weaker, cheaper fasteners. The good part is, once you've purchased the tool, and a few extra nutserts, you'll find several uses for them for the rest of your life. Good luck. Below is an Amazon link to a nutsert tool and various nutserts. Again, I use the steel versions.
Scott
Nutsert tool and various nutserts
Scott and Karla
SDFD RETIRED
KI60ND
Fleetwood_Coupl
FIRE_UP
So here I am ready to get organized drilled small pilot holes in the back of the basement to mount some fancy spring clips and it appears this is just Styrofoam and nothing for the screw to bit on. Does anyone know if there is any support beams or studs in these compartments ?
First off, I want to thank all of you for the nice comments. As stated, it's kind of a hobby for me now that I'm not doing it for living/overtime assignment.
Fleetwood Couple,
Many of these compartment walls are lined with a foam. There should, be a light duty aluminum backing behind that foam. One of the first things you or, anyone intending on mounting things on either the back wall or side wall of a compartment should do is, try and investigate just what's behind that wall you're getting ready to drill a hole through. Sometimes you need to get under the coach and probe around, do some measuring, anything you can, to make sure that you're not going to drill into a FUEL OR WATER TANK or, anything else of importance.
But, on many of those walls, they are basically light skinned aluminum, steel or possibly plastic or fiberglass walled cabinets with foam in between the skins. So, if and when you drill, do be careful and when attaching a bracket/clamp/tool holder/etc. do not screw down things too tight. You'll crimp the two sandwich walls together or, possibly even pull the screw head or nut right through the light skinned wall.
I've used many body washers on the back side so that will not happen. It spreads the load out for the clamping screw and nut. As to your question of "Studs", well, not that I've found. For much of the mounting of many of those brackets and holders, it was "blind" fastening. What that means to those of you that are not aware of that term is, you cannot get to the back side of the wall with a nut or, backing of any type for the screw (that holds the intended bracket)to attach to.
In that case, I use what's called "nutserts" or also known as "Rivnuts". They are a fastener that acts much like a rivet only, there's machine screw threads left when you remove the mandrel. Then, all you do is put your bracket in place and, screw in a machine screw. That's much stronger than using sheet metal screws.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
lfilk
I want to be Fire Up's neighbor.
Fleetwood_Coupl
BillsMax
Fire Up,
That's the neatest basement I've ever seen. When can you do mine????
2008 Monaco Signature 600Hp. 2013 Honda CRV
Executive45
FireUP.....once a fireman always a fireman....:W......Dennis
FIRE_UP
Billinwoodland wrote:
Fire up, awesome job. My dad was great at organizing storage areas like you are. For me, well, I know there's a 10mm socket in there somewhere!
Billinwood,
I thank you for your nice comments. While compartment organization was a side job for me as a fireman, on all new fire trucks we accepted, it's kind of a hobby now. It's really not that I'm anal about this sort of stuff, it's more about, if I want to do a 5 minute job, I don't want it to take 30 minutes to an hour 'cause I can't find the tools, equipment, items, repair parts etc. but, I know I have them.
I just like to be able to reach into a compartment, knowing EXACTLY where something is, get it, use it, put it back in the same spot when done.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
Billinwoodland
2008 Monaco Monarch 34 sbd
BrianinMichigan
Man those are some large compartments. It looks like I could hide away in there to get a snooze. 🙂
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
mike_brez
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
J-Rooster
I bought a large plastic tube at Camping World that has a screw cap on the end of it. The poles fit right inside of it! Works great!
