โOct-10-2004 04:24 PM
โSep-16-2008 08:47 AM
โSep-13-2008 05:56 AM
Paul Turpin wrote:
Just found out that I have to stay in Ohio until Nov, I am going to get cold. Never had to stay in a cold area in a RV before. Has anyone out there stayed in their P/A when it can get to 20 - 30 degrees? Is there some areas in the P/A that I must watch out for freezing the water pipes? I have a extend-A-stay ordered so I can use outside propane tanks to keep the furnaces running and not have to move to get propane tanks filled.
I noticed that the rear bedroom furnace has a heater pipe to the basement, but it is in the very rear of the basement and I am concern about the fresh water tank, water pump and pipes up to the front of the basement.
โSep-11-2008 02:10 PM
โAug-25-2008 09:24 AM
โAug-25-2008 08:43 AM
โJul-31-2008 03:14 PM
Ltcspec wrote:
It has been over a month since the last post. Hope everyone is out enjoying the summer and the comforts our Pace Arrows offer!!
โJul-22-2008 07:18 PM
โJul-09-2008 03:32 AM
โJul-03-2008 09:20 PM
โMay-27-2008 05:57 PM
โMay-27-2008 05:17 AM
Jim Bakker wrote:
I think the converter location varies, depending on the floor plan. On my 2004 36B it's below the cabinet under the vanity sink.
โMay-25-2008 03:44 PM
glewis wrote:
Took lightning hit thru plug in oxford,Ms week ago. Took out plug, coffee pot,back tv,microwave(still checking),poped fuse on fridge(Found and fixed)I now have no charging system for my batteries. Is my converter in the fuse panel under the sink? Is there a fuse somewhere I can check?Charging batteries with plugin charger for now. also my generator is still putting out voltage but not converting to 12 volts hope it is same fuse or problem. In Jackson, Ms. on a job right now. Thanks GREG Email hgcjlewis@gmail.com
โMay-23-2008 04:40 PM
Converter is located under the washer/dryer. You can see it if you take out the grill at floor level unjder the hutch in galley area, (under fold-up table in center). The converter is very difficult to get to and probably requires removing washer/dryer and lifting w/d floor. Can also get to part of the converter by removing the propane detector, although this may be difficult. My detector was "cemented" in with foam insulation. I was checking my propane detector, not converter so I can't tell you any more.
โMay-23-2008 04:01 PM
โMay-23-2008 10:04 AM
