looking for owners of 2004-2005 Pace Arrows
Jim_Bakker
I'd like to make contact with others who own one of the new (2004, 2005) Pace Arrows so we can share experiences, problems, good things, etc.
Jim and Suzi Bakker
Carmichael, CA
2004 Pace Arrow 36B, Workhorse W22
Ultrapower upgrade
2006 Honda CR-V
1,941 REPLIES 1,941
Paul_Turpin
jandn73 wrote:
My '04 Pace Arrow 37C runs electrically on shore power but I get no power from my generator. The circuit breakers on the genset are not tripped. This situation has occurred intermittently for the past three days.
I'm thinking my automatic transfer switch is not functioning properly. I will check it tomorrow for power from the genset into the switch and then see if I have power coming out of it. Is there anything that can be done to a malfunctioning switch to repair it or is it replace only?
Anyone know where it is located on my coach?
Thanks!
Jim
Asheville, NC
Jim, did you get it fixed? You should also check the power line coming into the Load Center that should be under the bathroom sink. Open up the 110 side and you should see the 10-2 Romex coming in from the power cord and the 10-2 Romex generator power cord. If they are not marked inside the box, remove the four corner screws and the complete box can be pulled partway out of the sink cabinet and check the 110 wires going into the box for markings. Check to see if you are getting power from the generator also check to see if you are getting a good connection on your generator wires. I had a bad connection on a 110 wire that had to occur after 2 years of driving down the road. Good luck and let us know how it worked out.
Paul and Sue
2004 Pace Arrow 37C
Workhorse
2006 Saturn Ion
jandn73
Thanks!
Jim
Asheville, NC
Paul_Turpin
Fyr guy wrote:
HELP! Over the weekend my buddy went to his storage yard to get his '05 PA to come to CA and found the coach had no house power. The steps didn't even come down. He bought 2 new house batteries and still no house power. He had stored it with the house kill switch activated but now he can't even hear the switch noise it makes when turning it on/off, any suggestions??
Sandy
Fyr guy,
Did your friend get his Battery Control Center fixed? Here is a web site that has good info and repair photo's on this and a few other repairs. www.2manytoyz.com/repairtips
Paul and Sue
2004 Pace Arrow 37C
Workhorse
2006 Saturn Ion
Fyr_guy
Bird Freak wrote:
FYR GUY
I just took the screws out of the bottom strut mounts, moved the doors up where I wanted and reinstalled the screws in the new location.
Bird Freak, I was hoping it was an easy solution. I'll do that this weekend. Thank's!
BTW guys, if your ever around the Central California coast, check out Wine Country RV Resort. It has my seal of approval.
Sandy
"Patriotism is not a short and frenzied outburst of emotion but the tranquil and steady dedication of a lifetime."
-Adlai E. Stevenson, Jr.
2005 Pace Arrow 37C "Bronze" Workhorse 8.1 "Ultrapower" upgrade
2004 Honda CRV
Bird_Freak
FYR GUY
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
Fyr_guy
I believe I read a topic on moving/replacing the existing gas struts to allow the compartment doors on the curbside to be opened at a greater degree, anyone guide me to that topic? I'd rather not go through 100 pages to find it but I know someone out there knows. Thank's in advance.
Sandy
2004 Honda CRV
dkingdoe
UPDATE...We ended up taking it in to the dealer and I'm glad we did 'when' we did because the MOTOR was bad and we just did make the two-year warranty :E deadline.
Something else that we had to have replaced was the wind sensor (still under warranty) because it continuously beeped in the enabled (ON) position (we were still able to use the awning).
Thanks to all of you for your suggestions.
dkingdoe wrote:
HELP :? NEED SOME SUGGESTIONS:
Our Kwikee steps won't extend. We've located the fuses for the step motor, and step switch. Checked to see if they were bad -"NO" - but replaced with news fuses anyway - still no change. :h
Any and all suggestions would be greatly appreciated
... before we have to take it in to the dealer. ๐Ÿ˜ž
Stan & Doris ๐Ÿ™‚ (Retired 2012)
'13 Coachmen Pathfinder 404RB
'17 Jeep Grand Cherokee Limited/Toad
bricot
Make sure you get the correct antenna as well! The prior owner installed a CB and it didn't work well, range wasn't good, came to find out he used a grounded antenna (one design to me mounted to a METAL vehicle), I replaced with a non-grounded type and it works much better.
Paul Turpin wrote:
tuff lyf wrote:
Paul Turpin... Maybe you or someone with the same make and model as me can tell me... Are there any cb hookups that come standard under the dash... Thanks
Not on the P/A I have. I didn't want to drill a hole in my rig so I got an antenna that sticks on the window and I ran the wire to under the dash. Again with the dual pane glass, I had to put the antenna on the little window on top of the driver door because the window antenna will not work thru dual pane windows. I don't use the CB very much only when there is a traffic backup to find out what lane to be in. I have found the window antenna does not have a long range.
2004 Pace Arrow 36B, 8.1L, Ultrapower upgrade, Trac Bars, Safe T Trac
Fyr_guy
Sandy
2004 Honda CRV
runaground
Is the rocker switch by the door in the proper position. Steps will not extend if turned off.
Larry / Cathy Hawkins
Pace Arrow 37C W24
R2Dillon
Also, check to see if the magnetic switch that tells the step to retract is not working.
Richard Dillon
2004 Pace Arrow 37C
Honda Pilot toad
3 Pomeranians, 3 Children
Fyr_guy
dkingdoe-
First off, call the manufacture Kwikee I've heard they have excellent customer support. You may save yourself a trip to the dealer. Here is the link.
2004 Honda CRV
dkingdoe
plodder
Fyr guy / Richard -
Thanks for the responses. I believe the upgrade is moving up on the list of priorities. Thanks again.
2004 Pace Arrow 37A
2002 Kawasaki Vulcan Classic 1500
2000 HD Road King Classic
1997 HD 883 Sportster
lovnlife
Jim Bakker wrote:
Right from day one the automatic leveling system has lost stability, overnight at first, now right away because one of the jacks almost immediately lifts off the ground. It goes into the shop next week and I hope they can fix it this time. Has anyone else had problems with the leveling system? I recently met someone with a 2005 model; it has a different brand of leveling system, not PowerGear. Is this an indication that Fleetwood recognized a problem?
When showering, lots of water flows from the backflow prevention valve on the shower faucet hose, regardless of where the shower head is positioned relative to the backflow prevention valve. The dealer has ordered a new hose and faucet, but Iโ€™m skeptical that will solve the problem. Anyone else had this problem? .......
Jim,
The Pace Arrow shares many of the same parts with the Providence. I too had the shower backflow valve problem. The dealer replaced the hose/shower head assembly under warranty. Haven't had a problem with that since.
Regarding the Powergear leveling system. Your's is a bit different than mine, but had mine replaced under warranty 3 times, finally had them install a brand new 2004 Powergear system that I heard was flawless. No problems since. It's been almost 2 years.
My Biggest recurring pain in the rear was actually located on the roof. The KVH satellite dish gave me problems until about 6 months ago. It apparently took KVH 2 years to fix programming bugs. Works fine now.
Scott
2005 Fleetwood Providence 39S
