What's the voltage if you check at the outlet?
When you apply an electrical load, one of the side effects is it pulls the voltage down. There 3 primary things that impact how much the voltage is pulled down:
- How many amps.
- How long is the electrical cable/wire run (if you coil up 100ft of cable, it still counts as 100ft)
- How thick are the wires
(there are a few other things but not too relevant to this discussion).
The air/con is generally the biggest load in an RV, so relatively high amps. (and as the voltage drops, the amps increase to compensate)
You've had to string together multiple cords, so relatively long cables.
You say it's 30amp service. Is it really 30amp service or is it a 15/20 amp household plug with an adapter. The wiring in your house counts as part of the cabling length and if it's thin, that could be increasing voltage drop.
Dropping by 3 volts is not uncommon with a heavy load like an air/con. If you are starting with a good strong supply up around 120v, that leaves you at 117v which is perfectly fine.
At 108v, that's getting borderline where I would be looking at pulling out the generator. Keep in mind, as houses in your neighborhood turn devices on and off the voltage will fluctuate, so it might be 108v while you are looking and it might drop to 105v a few minutes later.
I'm speculating a bit but if the 111v is while nothing is on in the RV (negligible voltage drop), the voltage at the outlet is likely marginal. Items you can check:
- Are all the connections in good shape with no corrosion? If you are capable, check inside the outlet and at the breaker panel for corrosion or lose wires.
- Check the voltage at other outlets around the house. If they are all down around 110v +-, it's likely nothing wrong with your RV and just that your house has low voltage. You could check with the power company but unlikely they would do anything about it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
