Motor home chassis pro's and con's
LA-REDNECK
Thoughts on Ford vs Workhorse chassis.
LA-REDNECK
2013 Tiffin Allegro Open Road
2017 Acadia
17 REPLIES 17
Bruce_Brown
Moderator
Moderator
Flip a coin. If it matters to you Ford is still building MH chassis, Workhorse gave up on MHs.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Dale_Traveling
Each have good points and not so good.
Personally I prefer -
Coke, Mary Ann, Almond Joy, right Twix,,,,,
2006 Hurricane 31D built on a 2006 Ford F53
Jim_Norman
That is an extremely open question. Both have their adherents and their detractors. Unless things have changed, a WH is not going to be new and you MAY have issues getting service locally. They did have an issue with brakes at certain times. They also had an Allison Trans which is a plus. The older Ford engines had some issues. The newer units with the upgraded engines are OK.
If you are talking handling, I can only speak to my two Ford base units. They were OK, especially after I did the 'cheap fix'. Between the two I ran up over 50K in 9 years. I would concentrate more on floor plan and the condition of the House. Of course you want to do a mechanical check, but if the house is coming apart at the seams does the chassis matter?
2016 Tiffin Allegro Red 38QBA
2008 Jeep Liberty (aka FireToad)
