Black and grey tank sensors
roadrat57
My newly purchased 2008 Fleetwood 31lx shows both black and grey at one third full. The tanks are empty. Did some research and found I can possibly clean the sensors a variety of ways.
Make some sense the lowest sensor for each tank is experiencing a bad read.
Any suggestions, as usual, would be greatly appreciated. I have used this forum frequently and I have very much appreciated all the responses.
Thanks!
17 REPLIES 17
BigBlockTank
mccsix wrote:
3-4 oz of Dawn after every dump add water and the ride home keeps them clean and accurate on my 10 year old MH.
This is about the best I've found. I started working on motorhomes almost 22 years ago. This is about the easiest way to do it.
Ice really doesn't help much, it's 'materials' that are dried onto the sides of the tank at the sensors. Fill your tanks to about 2/3 or 3/4 full, and go for a 45 minute ride on a turning road, not the freeway. Dump, and if it's gonna help, it'll help then.
crasster
All depends on how brave you are to venture your arm and/or sprayer into the deep realms of the black tank. For me, ice down the toilet. A lot of it. Fill it 1/2 full then take it for a ride to hopefully break junk up off the sensor.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Tinstar
I use one of the directional tank sprayers. Of course that will depend on where your sensors are in comparison to the toilet (straight down toilet only and it won't work with curved toilet drain pipe). Just point it toward the sensors and work it around. You can spray the walls in addition to the sensors. I also use 5 gallons of water and a good bit of Dawn before traveling to clean the inside of the tanks. Once or twice a year I'll use Calgon water softener (NOT Calgon bath oil) in the tanks (makes them slick so "stuff" won't stick to the walls.
One of these:
:CNever pass up a chance to go somewhere:C
roadrat57
Thank you all for your comments and techniques. Always appreciate.
Roadrat57
AllegroD
After rinsing thoroughly, at end of season, I do a final fill (full), add liquid water softener, dump and rinse.
BigRabbitMan
Let us know what you did and if it worked.
BigRabbitMan
Gas to Diesel Conversion project
76 FMC #1046, Gas Pusher became a Diesel Pusher
Discussion thread on this site
"You're never too old to learn something stupid."
kdk
As previously mentioned, google the GEO method. Dawn dish soap and calgon water softener. Do this and drive to your next camp site and drain. It may take more than one cleaning but this method does work. I don't think driving around the block will be a long enough trip. I do this about twice a year and have no more issues with the sensors.
Blessings;Keith
06 Holiday Rambler Ambassador
2016 Ford Explorer twin turbo
mccsix
Clay_L
The problem is not the sensors being dirty but is due to the tank walls being gunked up and fooling the sensors.
Even the non-contact sensors on the outside of the tank can be fooled if the walls are cruddy enough. SeeLevel even points this out on their web site.
The SeeLevel web site says "If sludge buildup in the tank becomes extreme the gauge will cease to operate (the tank will always read empty), so by monitoring the signal level the tank can be cleaned before the buildup gets excessive".
From HERE
Anything you do to help keep the tank walls clean may help.
Flushing, adding some detergent and water before you drive for a day or so might help.
I have the TrueLevel non-contact system that Winnebago went standard with in 2005 and right now my black tank reads full when empty. The gray tank shows 2/3 full when empty.
Over the eleven years we full timed I tried everything people say will work and nothing worked.
If I pressure washed the inside of the black tank (have done that twice), the level would be measured normally for a few months and then start to lie.
I think the problem is worse for full timers and that may be why some weekend or short term campers find that detergent or some other method works for them.
I ended up just dumping it every ten days and didn't worry about it anymore.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
DutchmenSport
You can try all kinds of new-fangled ways to try to clean the sensors, but the easiest and simplest is to simply drain the tank completely. Then add about 5 - 10 gallons of water. Now dump a couple cups of dish washing power down the toilet and go for a 30 minute drive! Once you get the camper back home, drain the tank again. Not only will it clean the inside of your tank, but it will also clean the sensors. If this does not work, then your sensors are probably shot!
If you want to use Dawn Dishwashing liquid down the toilet instead of laundry soap, Dawn works VERY well also. Pour a 1/4 bottle of Dawn into the toilet with about 5 - 10 gallons of water and go for the drive! Clean as a whistle! And very safe and sewer / septic tank friendly too!
lanerd
Sounds like the previous owner(s) didn't take very good care of their black tank. Yes, sensors can be troublesome but also can be fairly accurate if the tank is subjected to a procedure that will prohibit build up on the sensors.
I have found the best way to accomplish this is to empty the tank and flush out prior to traveling. I put about 5 gallons of water in the tank along with a cup of liquid laundry detergent (I use Oxy-Clean) and a 1/2 cup of Calgon water softener. While traveling to my next destination, the solution will slosh around in the tank "loosening" any residue left in there. Upon arrival at my destination, I'll drain the tank once more and put another 5 gallons back into prior to using the toilet.
This procedure has worked for me will all my rv's from our first single axle trailer to our 44' motor home and I highly recommend it.
In the OPs case, this procedure might take two or three trips to eventually get everything off of the season.....but it will work.:C
Hope this helps
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
dalenoel
I always figure how long we can go based on experience. However, my gauges work very well and seldom plug up. I never use the backflush system except at the end of year and I'm going to winterize.
The only treatment we use, never have had any smell, is from Unique - DigestIt. A natural treatment and it will dissolve all items keeping the system flowing well.
OK now that I've said this it must be time for me to be attacked. Go for it.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
DrewE
For me, rinsing out the tanks (using a spray wand for the black tank) and letting them sit makes the sensors work properly. Putting some cleaner like dishwasher detergent in the water and letting it sit and slosh around would probably also do a nice job...or you can look up the "GEO method" for tank cleaning here for a rather more complicated but apparently quite effective tank cleaning regimen.
There are a number of people who say the sensors never work reliably and hence are useless. I find mine actually work fairly well most of the time and I do find them handy, though not essential. I wonder if the people who say they're useless say that because they've never had ones that work consistently; it strikes me as perhaps the attitude of someone who has a broken gas gauge and says that the gas gauge is not very accurate and you can always figure when to gas up based on mileage since the last fill-up. Those are both true statements, but it doesn't mean that a gas gauge, or a holding tank gauge, is not also handy.
Old-Biscuit
2oldman wrote:
The common response to this is: forget about those sensors. They rarely work properly.
You can obsess over cleaning them only to have them gunk up next time tanks are used.
Tank level sensors like battery level monitor are just 'do-dads' for salesmen to point out. Oo-Ahh.
Toilet 'burps'----time to dump black tank
Sink/shower draining slower....time to dump grey tank
Water pump goes 'brrruup'....need more fresh water
After a few trips you will get a handle on how long before each each tank fills up.
Dump when full
