โJan-26-2020 09:40 AM
โMay-04-2020 04:07 PM
โMay-04-2020 12:55 PM
โMay-04-2020 11:38 AM
โJan-30-2020 01:37 PM
โJan-30-2020 09:56 AM
โJan-30-2020 09:39 AM
klutchdust wrote:
Yes, you are correct. Iโll change my reply :
โ Using plastic shims sounds cheesyโ
Thanks for the heads up.
โJan-30-2020 08:32 AM
โJan-30-2020 03:59 AM
klutchdust wrote:if you would PROPERLY read my post, I did say PLASTIC shims. And they do work.tarnold wrote:
For the anti rattle. Go to a home store and buy a pack of plastic wedge/shims used to install doors and windows. Jam the narrow end in the receiver and snap off if you want the excess. No more wiggle.
I prefer to use a large bolt with washers and nylon lock nut. Once tightened there is no chance of any rattles .Using pieces of wood sounds cheesy.
Unless you use a locking hitch pin (and I already had one failure on those) you risk losing or having someone tamper with the pin.
โJan-28-2020 09:16 AM
โJan-28-2020 08:07 AM
โJan-27-2020 03:35 PM
โJan-27-2020 07:27 AM
suprz wrote:
https://www.discountramps.com/hitch-mounted-steel-motorcycle-carrier/p/MCC-600/
We have a class 3 hitch on our class C and use a motorcycle carrier with a 600lbs max capacity with my wife's Suzuki Boulevard S40 (maybe 450lbs soaking wet) ...
โJan-27-2020 05:37 AM
โJan-26-2020 06:18 PM
