May-23-2017 11:08 AM
May-28-2017 11:09 PM
Effy wrote:et2 wrote:
This is what some use ( we do). It works, in use for 4 years, no play. No drilling or tapping required. Just re-torque once a year.
http://www.blueox.com/towing-accessories/bx88224/
Did I read that right? $70 ? wow.
May-28-2017 01:14 PM
May-28-2017 07:48 AM
May-27-2017 11:50 PM
May-25-2017 06:11 AM
May-24-2017 05:26 PM
May-24-2017 10:11 AM
May-24-2017 08:59 AM
CVD wrote:
I have vertical looseness, as well as horizontal. Shouldn’t I be tightening the fit in both directions? Makes me think I should drill and tap 2 holes; one on the top and one on either side. Make sense?
May-24-2017 08:55 AM
May-24-2017 08:31 AM
willald wrote:Effy wrote:tarnold wrote:
Go to your local hardware store and buy a pack of plastic shims. The kind used to install doors and windows. Drive the narrow end into the receiver till tight. Break off remainder sticking out. Solid as a rock!
I tried this, a few issues, for one unless taped, the shims will eventually work their way out, secondly, when they are jammed in there it's almost impossible to get the ball (or whatever you have installed for towing) out. Imagine jamming in wedges which also wedges whatever device you have in the receiver and now that the shims are broken how do you remove it? And left with broken shims, what do you do next time? New shims?
Ahhh, you just confirmed what I suspected and mentioned in previous post, Effy. Don't think I gonna mess with shims, as we do have to take the tow bar out from time to time, to put a bike rack on back of the Motorhome to carry bikes instead of towing.The solution I proposed earlier works great and is so simple not to mention free if you have the tools. Simply drill and tap a 3/8 hole in the top of the receiver, screw in a bolt and snug up when you are towing, back off to remove. Easy cheesy and works like a charm. Took me a total of 5 mins and was free. Been using this method for 5 years. Never any movement, never any issues. And takes only a few seconds when hooking up. Nothing to remove or add.
I like that idea, but my issue with it is, I worry about that weakening the hitch receiver and causing much bigger problems.
Will
May-24-2017 07:32 AM
May-24-2017 07:10 AM
May-24-2017 07:03 AM
May-24-2017 06:51 AM
