โJul-01-2013 10:25 PM
โJul-03-2013 03:40 AM
dreamco wrote:Raymon wrote:dreamco wrote:Raymon wrote:
I am not familiar with the codes. When I had my c-class with a Ford chassis, one of the things I did after only a few thousand miles, I changed the transmission fluid to full synthetic. It was just a personal decision I made based on my automotive experience and knowledge. I know some people will most likely disagree and say that I wasted money. It gave me peace of mind when climbing long, steep grades in the Rockies.
Ray
I'm definitely converting to full synthetic on my next service...probably as soon as I get home.
the tranny fluid already is full synthetic.
โJul-02-2013 10:54 PM
FuzzyKnight wrote:
This transmission does not like to tow any thing!!! If and when you do tow any thing do not use OD. It will burn that baby up!! Ask me how I know - 5k later!!
Good luck I hope you make it home!!
โJul-02-2013 10:35 PM
Ray
โJul-02-2013 10:29 PM
Daveinet wrote:
Not a Ford guy, but I would assume there are 2 identical sensors, one on the input and the other on the output. Swap the sensors and see if the problem changes, or the error code changes to the front. That will let you know if it is a wiring problem or a sensor problem without spending money.
โJul-02-2013 09:36 PM
โJul-02-2013 09:33 PM
Ray
โJul-02-2013 09:15 PM
โJul-02-2013 03:52 PM
โJul-02-2013 12:55 PM
You did not mention whether or not you have ever had the transmission serviced. Ford requires the transmission fluid to be changed every 30,000 miles. If not, the transmission will "stutter" when climbing hills or towing. If your fluid has not been changed, I would start there because it should be changed and it just might correct your problem. If changing the fluid does not correct the problem, then you can do the things other posters have suggested.
Ray
Hi Ray,
The coach has 48k miles on it...first trans service was at 18k, second was at 36k so I'm probably due for another anytime.
Do you think it would code p0720 if it needed a service though?
โJul-02-2013 11:53 AM
โJul-02-2013 11:47 AM
Ray
โJul-02-2013 10:17 AM
don/lou wrote:
Replace the speed sensor its on the diff on drivers side top front
About 45.00
Don
โJul-02-2013 10:07 AM
โJul-02-2013 09:23 AM
