New owner electrical problem/question
rjjr
I parked my motorhome in our storage unit and tried to plug into a 110 outlet. It immediately tripped the circuit breaker. I was using the 50 amp shore power cord with an adapter to plug right into the outlet. It's about 25' long.
I checked and rechecked everything in the coach and nothing was turned on. I even had the fridge switched over to gas only. I wouldn't think the battery charger would pull enough amps to trip the breaker.
Any ideas?
10 REPLIES 10
calamus
it WH for Water heater! If the water was HOT why would you need to heat it? Sorry a Plumber Pet peeve. The outlet you are pluging into is a GFI? The more they trip the weaker they get So the outlet may need changed also. If a new one trips you my have an issue in the camper
2015 3500HD Chevy Dually Duramax, 2008 Sundance 2014 22'SSX bennington pontoon
rjjr
It's a g f I outlet
ScottG
Are you tripping a breaker or a GFCI?
If it's the latter then you have a problem someplace - probably the RV fridge.
YC_1
hwh hot water heater
Yes your battery charger could be enough to trip a small breaker. You did not mentions the size of the breaker.
Your panel may allow you to set the charging level from 10% to 100% for example. At 100% it could easily overload a normal outlet if the batteries are being charged from a low state.
Or if the breaker is a gfci it may not like the setup as well.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
mccsix
Easy to forget about the hot water heater HWH, done it a few times.
rjjr
newman fulltimer wrote:
Is your hwh off on the electric side
what is hwh?
No idea what else is on the circuit. I really just want to keep the batteries charged. Should I buy a little charger and hook it up to the batteries?
stickdog
Your 50 to 20 adapter could be faulty.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
newman_fulltime
calamus
Bad Circut breaker if you have plugged the coach in else where with no issues.
Fleet_Man
You should be OK, we have used the 110/15 amp to 50 amp adapter many times with no problems. Do you know of anything in the storage unit on that circuit that has it at capacity? Try another outlet that you know is not providing power to anything else.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
