New Tires
anconn
I have read so much on here about tires aging out. I understand it, but what is the time. I have heard anything from 6 years to 10 years. And how likely is it to be a problem if you go an extra year?
2002 Seabreeze 34' MH
2005 Jeep Liberty
13 REPLIES 13
J-Rooster
prstlk wrote:
What kills Rv tires the most is U V Rays ie sunlight
Second is tire pressure
Keep em covered even for just a few days
Check tire pressure weekly with good a guage when your on the road. Visual every day you move a must. And always before you move it when it's been sitting. Even 20 miles on a heavy loaded under inflated tire can break belts and or cause future failure
How any rv tire "looks" doesn't mean a thing
I agree with your post and I don't have any facts to back this but, I can't tell you the number of RV's that I see in driveways at home and campgrounds with blocks that the RV drives up onto and the tire is not fully on the block! Result is inner sidewall damage, which you can't see and it can cause tire separation! Then the tire manufactor is blamed!
Bruce_Brown
Moderator
Moderator
2oldman wrote:
Depends on where in the country you are. Here in the desert SW where there's lots of dry and sun, 4 years is not bad.
I would agree with this one. A tire that has spent its life in the hot, dry deserst sun won't live as long as a garage kept tire that only sees the light of day when it's out for a trip.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Don_Don
goodcruisin wrote:
Mine were 9 years old. For the past three years I took the MH to the tire dealer for inspection and was told they looked good. A few weeks later I experienced an inner blowout. After the tire blew the tread came off. The resulting damage was nearly as much as a set of tires. I will now replace my tires at the 5-7 year mark.
What's to say you didn't run over something? Inspections can't predict that.
goodcruisin
John (USN Ret) & Debbie
Tux (Amstaff/Dalmation mix)
'96 Monaco Windsor 36' DP 8.3 Cummins for chillin'
985 HP Dragster for thrillin'
prstlk
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
darsben
If you push the envelope to far it could cost you more than the new tires. I had a 6 yer old tire suffer tread separation and the tread went into the fresh water compartment and destroyed the tank, Pump and some plumbing not to mention the floor in the compartment. I did the work myself to repair but the cost was still near $1000.00 for the parts.
SOOOOOO .......
Traveling with my best friend my wife!
wallynm
Read this thread.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Bob___Ann
Mr.Mark wrote:
Our tires were 7 yrs. old with 57,000 miles. I didn't want to push the envelope so I bought new Michelins through the FMCA program. Pete's tire service gave me $50 each for the take-off's (8 tires).
MM.
Ditto!
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
J-Rooster
There is no limit on tire wear due to various conditions that effect a tire. But to get the maximum life out of your tire you should have a strict maintenance procedure that you follow and take your coach down to your tire shop once a year to have your tires inspected. I had my last set of tires last 10 years using what I suggested. It's really important to keep proper air pressure in your tires, keep some of the coaches weight off your tires (when stored), don't use tire black on the sidewalls of your tires and use a barrier between the ground and your tires and block out sun exposure to your tires. Sorry, I couldn't give you a specific number of years everyone's tire history is different.
Mr_Mark1
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
timmac
6 years should be the max for tires on a motorhome.
Fishinghat
Our DOT suggests a limit of 10 years. However, in BC you get about as much sunlight as we do in Western Washington, so 10 years is a reasonable estimate for a limit.
I replaced my tires at 10 years although they didn't look hardly used and had most of the tread left. The tires had about 50K miles on them. We spent about 4 months in Yuma each winter and that may have "aged" the tires more than while up north. We never had any tire problems.
Bottom line though, you don't want to have a tire fail. Most of us don't carry a spare, and if you do, you'll have some difficulty trying to change it. Those things are heavy. A blown tire can cause other damage to the coach and may even cause you to go out of control.
Since your coach is a 2002, I suspect your tires may be more than 12 years old. You may be pushing your luck.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
2oldman
