Newmar owners - broken baggage lock help!!
klm
I have a '02 Newmar. The baggage doors open from bottom and swing up. One of them won't open. It does "unlock" with the key, but nothing happens when I lift the latch. The plunger is not moving. It is a stand alone compartment, no access from other bay doors. OK, is there a trick someone can share with me on how to jimmy the door open?
thanks, Kathy
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
14 REPLIES 14
mtrumpet
TechWriter wrote:
klm wrote:
OP back - still no luck - but will keep trying - not today tho - cold, windy and rainy!!! I will call Newmar today and order the link part, so WHEN I finally get it open, it'll be an easy fix.
Order a dozen of them because they'll keep breaking.
X2!
If you have a local RV dealership nearby, they may have them in the Parts Dept. Those latches are not exclusive to Newmar.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
TechWriter
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
wa8yxm
Trimark locks are known for this...
Now you will need, a SMALL inspection type flashlight, Mine is a flexible LED thing (Led on the end of a bendable wand about the size of a small soda straw).
And a tool to press the lock plunger with,, Screwdriver, (Fairly long and thin) or a seal pick works here.
Get under it and look at the latch.. You can slide a shaft in and push up on the plunger with it.. Open the door, catch the plunger and spring when they fall out.
Then,, Get a small mending plate (This is a flat steel strip with, in the smallest size, two screw holes) And piecing the plunger together machine the back side of it so you can lay the mending plate into a slot you create (Wide flat slot) drill the holes and insert screws make sure the back is smooth, and trim any excess screw as well.. You should be able to re-assemble, this is better than the OEM which used cheap pot metal that .. well, broke on you
OPTION 2: (Opening instructions are the same) if the plunger (and spring) do not pop out,, You take off the backing plate and you will see what needs doing.
These locks are my greatest complaint. If you are in Upstate SC.. I can make house calls and show you one plunger I modified.
klm
TECHWRITER, I love your idea (great pics) - I am going to copycat you - for all my stand alone compartment doors (4) I don't want to go through this again - especially since one of my stand alone bays is the electrical!!! That would be a disaster if/when that latch would break. My coach is 12 yrs old - I'm a fulltimer so those bay doors get opened and closed a lot!!!
'02 KOUNTRY STAR DP
TechWriter
I used a Dremel to cut a notch in the latch the holds each basement compartment closed:
This way I can just use a screwdriver to push up the door bolt and then open the door. A broken door can now be open rapidly which could be very important for a couple of my basement doors.
Of course this makes it easier for a thieve to open the door, too, but I'd rather replace the "valuables" behind a door than replace a door itself.
DISH TV for RVs
hipower
I have had to tackle this issue with my Dutch Star several times. I've accessed the latch from adjoining compartments and removed the back plate and also crawled under the coach and used a thin blade tool to depress the latch tongue to open the compartment.
After numerous cleanings and lubrications I found that the cross bar, shaped somewhat like a dog bone, tends to jump over the tab in the latch tongue and jam it in place. I added a small washer under the screw that holds the dog bone in place expanding the surface area that keeps it in place and this seems to have cured the problem. When these latches work they work just fine, when they jam up they are a real PITA.
mtrumpet
As others have suggested, try to get in from underneath with something slim and push the latch stem out of the catch. Take your time so as not to damage anything. Also, a call to Newmar might be helpful.
This same thing happened to me twice. Fortunately, I could get to my latches from adjoining compartments. Both times, there was a metal latch inside the assembly that broke. I was able to get replacement parts from a local dealership along with a couple of spares for when the next time it happens.
Mark & Cherie
Dennis_M_M
On mine the latch swings down to fit behind a bar on the compartment floor. Some of mine had very little purchase on the latch. On those it would have been easy to pull down on the floor of the compartment and up on the door to get enough clearance to open it.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
Retired_JSO
I can reach the dead bolt from under the door. The doors on mine are curved at the bottom but it can be done. I used a long slender blade/barrel screw driver and using a light, slipped it in being careful to not tear the gasket and was able to push the dead bolt in.
chucl66
Try to open by pushing up on the latch from the bottom. If it is like mine the latch catch is open on the bottom, push latch up by hand.
Chuck
Chuck & Laraine
klm
Op back. I will call Newmar tomorrow. Of course it breaks 3 days AFTER I left Newmar service center. Ugh. I did have another latch break but was able to get to it from another bay. Newmar sent me the part, link. It was an easy fix. But the bugaboo here is getting the bay open. Grrr
'02 KOUNTRY STAR DP
eheading
Have you called the Newmar service number?? If all else fails, I would call them, explain your problem and see if they might have an idea on how to get the door open.
Ed
ronmc
Lay under door and move door out, try and push latch with a screwdriver. There is a broken link in the lock. I had this, since it was on the toilet flush compartment, I leave it unlocked. Newmar stocks the link. Enter the part number on the lock plate to get a part number,
Ron
2002 Kountry Star
2007 Honda CRV
Used Brake Buddy
MountainAir05
Try pushing in at the lock with some pressure. I use my knee. Take it apart once open and clean and lube with dry lube.
