Nice clean hands while hooking up the toad
holstein13
A few weeks ago I was in the auto parts store and saw some cloth gloves at the register with the rubber coatings. I figured they'd be great for use at the truck stop when filling with diesel fuel.
Yesterday, I was about to hook up the toad when I thought of those gloves so I tried them out and it worked great. I hooked everything up and took off the gloves to reveal my perfectly clean hands ready for driving. No more wet wipes for me.
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
20 REPLIES 20
holstein13
Mr.Mark wrote:
I have tried numerous times to put up a pic. I used to have the '08 Dynasty on there but I cannot get a new picture back up. My picture size matches what is required but then it tells me the file is too big. I gave up.
MM.
Send me the file and I'll fix it up.
Mr_Mark1
holstein13 wrote:
Mr.Mark wrote:
PS. I like your new coach pic!
Thanks, it took me a while to cut out just the coach and toad and make the background transparent. When are you putting yours up?
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
bsinmich
Your hitch must be a lot dirtier than mine. I can hook up and go inside to eat with clean hands.
1999 Damon Challenger 310 Ford
mike_brez
I just make my wife do it after she is done dumping the black and gray tanks and rolling up the shore power cord and water hose.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
holstein13
et2
I have the cloth ones you buy cheap at harbor freight. Usually put them on initially but they end up off somewhere along the line. Now if I could just convince my wife to hook up the toad ... Problem solved ;). But I'm too much of a do it yourself if you want it done right person.
J-Rooster
I've used gloves to hook and unhook and fuel since I started RVing in 1976.
Mr_Mark1
I found a similar glove that is nylon with the rubber coating on the palm side of the glove in Quartzsite, AZ, across from the Big Tent Event. Only $4.00. They work well and launder nicely.
MM.
Mr.Mark
CarlGeo
down home wrote:
I buy boxes and cans of nitrile gloves that are impervious to diesel. Some come in light, medium and heavy duty. The Mediums seem to work fine but the next box will be heavy ones from Harbor Freight. They don't cost much and you just peel them off and discard.
The Roadmaster setup is without a doubt the dirtiest chore to hook up. I wash it down when we are at destination and relube with silicone.
Agree that nitrile gloves from Harbor Freight is the way to go. I buy a box about every year and it costs about $10 +/-. They are great for hooking up, dumping and other dirty jobs. Use and discard or depending upon use they can be reused two or three time. I would not want to be without them!
down_home
2oldman
CA Traveler wrote:
Not to mention the spilled diesel you walk around in sometimes...:(
You should see me dancing around that!
lanerd
travelzoo wrote:
I like the good old Brown Jersey gloves. They can be bought cheap at flea markets or even Walmart for .50 cents a pair.
Me too!
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
F1bNorm
Got a HF tote. Holds cables, pins, spares and a pair of work gloves. It also serves as a prop to hold up one arm while hooking up the other.
Norm
F1BNorm
travelzoo
