No House Power on Thor Hurricane - Help
LA88
I lost all power inside the RV. Both house and engine batteries are new. The house power only works when the generator is running. Otherwise, no lights, microwave, refrigerator etc.
Motor engine is running fine. I checked all the fuses and they seem to be fine. Any help would be appreciated.
RV: Class A 2007 Thor Hurricane, Ford F53 V10
11 REPLIES 11
LA88
Thanks everyone for chiming in.
No, this is while not plugging in and only running on battery. Let me try the black box reset as suggested. I had the BCC recall done recently and that wasn't it. None of the breaker under bed tripped so I know that wasn't it either. The auto-leveler works fine, just no lights and the vent fan is not working.
kimoson3
LA88,
Thor issued a Safety Recall Notice - 13V-265 earlier this year that covers 2007 - 2013 Hurricanes. The Battery Control Center (BCC) installed by Thor are defective, "which may result in all power to the chassis portion of the motorhome to be lost, including all lighting". All Camping World locations are aware to this recall and will repair at no cost, or call Thor at 877-855-2867 for instructions where to get repaired.
US Navy, Retired
'08 Four Winds Hurricane 33T
'02 Honda Accord w/Blue Ox and Brake Buddy
I_rv
its normal to loose power in a hurricane ha ha ha
accsys
Top, Center of your engine compartment, there should be a black box about 8" square. This houses your 12V controls. Inside, there is a small push-button, 50 amp breaker for your 12V. When we had a 2006 Hurricane 34N, this breaker would pop on occasion for no obvious reason.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
Goldencrazy
The assumption is that you are plugged in and that you lost power. When that happened your batteries did take over most of your functions through the inverter. You then started your generator and had electricity to all systems again. You use the microwave as your measure of whether there is power.
My micro does not work normally off the batteries but some outlets and many lights do so if you have lost all lights you have a problem with house 12 volt as well as external shore power. If my description is accurate then your problem is with the inverter or converter and you also have a poor shore power connection perhaps inspired by a surge. When fixed get a surge protector.
gone2dadesert
My microwave only works when the generator is running, it sounds like the battery disconnect switch is off. Did you have the recall done recently?
2011 Hurricane 31J
2008 Jeep JK Unlimited Rubicon
chucl66
Check your power cord. I had this happen to me, found loose connection on cord.
Chuck
Chuck & Laraine
garry1p
Check the circuit breaker at the power pedestal if on shore power.
If running on inverter the check the circuit breakers on the inverter.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
newman_fulltime
Sounds like a bad transfer switch or converter on most of them the converter is a deck mount if so you should have a plug on the back of the fuse box unplug the converter and plug it into a extention cord to the pedastal and see if you have power
It also could be as simple as a gfi plug needs reset
enblethen
Coach power for microwave and receptacles is 120 AC volts.
Are you plugged into shore power?
Try cycling your battery disconnect for the coach. Some are marked as "aux". If unsure, cycle both the chassis and coach batter disconnects.
Converter works off 120 volt AC. Since the coach works when genset is operating doubt whther it is the reverse polarity fuses in the converter.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
gsf35099
I had a similar problem & my fuse blew on the back of my converter.
I'm sure the experts will chime in here with more info shortly.
2005 Damon Astoria 3679
300 Cummins ISB 5.9, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
