norcold door fridge
poli964
Hi folks..,
Just out of curiosity....
While i was in vacation in Florida with my Safari Trek 2007 the refrigerator door broke directly in the bottom where you can find the hinge.This will be my 3rd refrrigerator door and the 2 other broke at the same place.
2 days later my brother in law who was in vacation with us with his Monaco Monarch 2009 has the same problem as mine the door refrigerator broke at the same place...
For sure Norcold known the problem but for what i know they never did nothig to fix the problem...
If i call them do you thik i can dio something for me and my brother in law.
Please help and is one of you ever encountered this problem.
Thanks
Robert
2007 Safari Trek
Robert
2007 Safari Trek
Outback Lodge
11 REPLIES 11
TomxxBev
Don't feel like you are the only one. I am on my fourth door. Last one they sent me a metal support to put on lower hinge If your's is a right hand hinge I have a support for it. they sent me one of each.
chiefneon
Howdy!
We've been there done that. I had one of the Norcold 1200 upper doors break first. I used JB weld to put it back together and its held up for four year no problems. Just recently one of the bottom door hinges broke. Once again I used JB weld to fix it. I used some Reflexic we use on our windows to cover the door opening while the JB weld was setting up over night. Installed the door the next morning. Never travel without JB weld.
"Happy Trails"
Chiefneon
Carvin_Marvin
Plumber John I did a similar repair 5 yrs ago.
PlumberJohn
Thought I was in a club by myself. MY Norcold lower door hinge broke off from the door,cheap plastic. I repaired it by making hinge out of
11/2" x 24" x 1/8" aluminum flat stock. Used the broken end as a pattern for shape and hole placement. Then cut total length to about
14" and the width to the width of the bottom of the door. Sheet metal
screwed the new hinge to the bottom of door and set it on the door peg ( used a couple of small washers on peg for height adjustment). Many happy miles later and still working fine.
falconman
There is a kit to re enforce an unbroken lower hinge although I think some have used it during a repair. A search on Amazon will give the info and part number.
I_am_still_wayn
When you load all kinds of weight on the door shelves and then bounce over the roads, the weal hinge is destined to break. Quit loading the door with stuff and the hinge will last forever.
Coyote74
I drilled through mine and put a thin bolt and nut through it. Covered nut with a little end cap from white closet shelf. Works for me. Doors are 2 expensive.
Joe Taylor , Good Sam Life Member
FMCA #285032
2004 Winnebago Adventurer 38R
Life's a trip, RVing makes it an incredible journey.
poli964
I also Glued mine and it support the trip back home but before to travel i took care to take out the wood exterior finishing door.
We will see with Norcold..
Robert
2007 Safari Trek
Outback Lodge
Bea_PA
It's a known common problem, one guy glued his, don't know how it held up. Others bought new doors with same weak hinge. So far so good with ours. Knock on wood.
Bea PA
Down sized Winnebago 2012 24V Class C
2003 Gold Wing 1800 recently triked (Big Red)
travelzoo
It's nothing new and having problems getting Norcold to do anything even when ours was still within warranty, I wish you luck now if it's out of warranty. We were told early on not to load the doors with heavy items even when sitting. We unload every thing from the door shelves when traveling down the road.
midnightsadie
have all paper work in hand and call them.
