norcold door panel removal
Carvin_Marvin
I want to replace the door panels on my norcold 1200 refer. Tried search but no luck. Thanks in advance for your assistance. Don't want to break the snap trim.
4 REPLIES 4
dougrainer
Some OEM's use a small drip of silicone to hold the door panels in place to keep from moving slightly. IF this is the case, you have to use a metal flat piece of metal to slide between the door panel and the door backer to cut that silicone loose. Doug
Gonzo42
When I got my unit replaced, it was simple to pop loose the edge and slide out the panel to move it into the new unit.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
Old-Biscuit
Norcold 1200 Installation Manual
See pg 6 for descriptive instructions
See pg 17 for referenced diagram
ThomBoles
Not sure what model you have or what the door looks like but I had to replace the door on our N611 and to get the panel off the front was a chore. It was glued into the track that it sits in. I basically destroyed the old door (it had a broken hinge already) getting the panel off the front of it.
Thom and Diane Boles
2010 Winnebago Vista 32K
