Nov-08-2016 11:20 AM
Nov-12-2016 08:56 AM
Nov-09-2016 07:04 PM
Nov-09-2016 10:55 AM
usersmanual wrote:Old-Biscuit wrote:
Fridge is telling you there is NO 120V AC available.
Test outlet.....if it is good
Then remove control module cover (have to unplug some of the leads to remove and check the 5A Fuse (glass fuse). That is for the AC circuit. If blown then also check the electric heater element-----it could be bad also.
yes I believe this has been covered several times here already
Nov-08-2016 09:00 PM
Nov-08-2016 08:55 PM
Nov-08-2016 06:18 PM
bigguyracing wrote:
My Norcold rv refrigerator switched from AC to LP today ! I am hooked up to 50 amp service. I checked all of the breakers. Everything else in the coach works just fine but when I put the refrigerator in the AC mode it starts to beep and displays no AC. When I put the refrigerator in AU mode it goes to LP.
Anyone had this experience with their Norcold refrigerator ?
oGary
Nov-08-2016 01:24 PM
Nov-08-2016 11:40 AM
Nov-08-2016 11:38 AM
