โJan-29-2016 07:15 AM
โFeb-01-2016 10:54 AM
โJan-30-2016 07:41 AM
Sfla2 wrote:smkettner wrote:ok mine is a 98 in the service guide it says towing or heavy loads every 3k & we are heavy most of all bigger "c" are close to max. I can send u the page if u want. Also mine says 5 k normal 3 k heavy, could be what they said back then
The only Ford book I see says 7500 miles for an E450. 5000 if towing. Do you have a link for 3000 mile recommended change?
โJan-29-2016 07:48 PM
โJan-29-2016 05:52 PM
โJan-29-2016 05:13 PM
smkettner wrote:when you look at the book see what it says abt heavy loads as we are all in that range, do mine every 3k as my book says based on load, foe lousy 25-30 $ (if u do it your self)not worth the gamble
I would check the level and go camping. First change at 5,000 miles or longer if the book calls for it. As long as you are not making half mile trips to the grocery every day I would change on mileage only.
Send in a sample if concerned. Never read a post where tested oil was over due full of condensation and acid build up.
โJan-29-2016 12:26 PM
โJan-29-2016 11:23 AM
โJan-29-2016 11:16 AM
โJan-29-2016 08:00 AM
โJan-29-2016 07:49 AM
โJan-29-2016 07:46 AM
โJan-29-2016 07:41 AM
โJan-29-2016 07:34 AM
โJan-29-2016 07:29 AM
