โAug-26-2013 06:02 PM
โAug-29-2013 07:14 PM
โAug-29-2013 04:15 PM
fighterpilota wrote:It's not just the 2000s Born Free models as you're reading here, fighterpilot.
Good information. Interesting to note even the Born Free model can have issues. And I hadn't thought about the cabover clearance lights leaking. Thanks
โAug-29-2013 05:07 AM
โAug-29-2013 12:56 AM
pnichols wrote:Right. That is another water source intrusion point on these rigs.Skid Row Joe wrote:
The overhead window also continues to leak even though the coach was returned to the factory at great cost for a complete sealing re-do - only to have the window start leaking again in a matter of months.
Just as a heads-up on the cabover forward facing window leaking. It may not be always this window which is doing the leaking. Leaking from this area could be the cabover lights. I disconnected mine and permanently sealed the hole in behind them with Eternabond so that they will "never leak" ... of course it means I have no cabover lights lit up whenever the exterior lighting is turned on ... even though the cabover lights are still there so it looks like I at least have them on the vehicle.
โAug-28-2013 06:51 PM
โAug-28-2013 02:28 PM
โAug-28-2013 02:09 PM
Born free are nice looking. All fiberglass. Do you have to worry about blisters in the fiberglass developing like they do on boats? Do they have any issues with leaks or are they essentially built as just three pieces? I could get along with the 26 model with the rear corner bed even though it doesn't have the booth dinette. Thanks for the suggestion.
mockturtle wrote:
Bought mine used in 2009 in AZ. There are some slight ripples on the side from heat warp but, because the sidewalls are not laminated, there is no 'delamination'. I had a leak in the front cabover window. It didn't leak to the interior walls but into the fiberglass cabover. No permanent damage and, though the fix was rather expensive, it was worth it. Also had a slight leak in an outside compartment that stained a bit of the carpet inside the compartment. Regardless of these issues, Born Free is a very well built motorhome and I would buy another one.
โAug-27-2013 08:52 AM
โAug-27-2013 08:38 AM
Regarding the blisters, we have had a number of fg boats and all have developed blisters. They are kept in the water but they bottom has always been painted to keep the growth at a manageable level. Notwithstanding that, water seems to find a way in. Even if cleaned an painted once a year. Now these are older boats, like 1980s models so previous owners might not have been as diligent as we are.
โAug-27-2013 07:12 AM
โAug-27-2013 05:44 AM
โAug-27-2013 05:26 AM
โAug-26-2013 09:57 PM
โAug-26-2013 08:58 PM
