Jan-25-2016 04:41 PM
Feb-01-2016 06:43 AM
Snowman9000 wrote:You can adjust the jets and that helps but I think the main problem is that the fuel drains out of the fuel line back into the main tank after sitting for a while. I put a clear plastic fuel filter when I changed it last time and I can see it go from full to empty after several weeks of sitting. It takes 3 tries to get the fuel pumped out of the tank to the carb to start it.
We took delivery of our RV within days of it coming off the assembly line. The genset has started hard from day one. I'm convinced they are leaned out too much.
The altitude adjustment is on the main jet, so I have read. I wonder if it can be altered.
Jan-31-2016 07:46 PM
Jan-31-2016 06:04 PM
Jan-31-2016 01:31 PM
Jan-31-2016 05:54 AM
Jan-31-2016 05:26 AM
Jan-31-2016 04:57 AM
Jan-30-2016 04:31 PM
two travelers wrote:
How long do you hold the prime switch on for? Is there a danger of flooding if held too long?
Jan-30-2016 02:56 PM
Jan-30-2016 02:44 PM
Jan-29-2016 04:19 PM
Jan-29-2016 10:49 AM
Jan-28-2016 01:53 PM
Jan-28-2016 11:18 AM
Effy wrote:
Yes this is normal. If it's been sitting more than a week I often prime it 2x and it starts right up. I could get away with priming it once but then it sits there and churns away trying to start. Hit the prime again and it starts immediately. If it's only been a day usually you don't have to prime it at all.
