โOct-04-2016 03:54 PM
โOct-08-2016 08:31 AM
โOct-07-2016 08:27 AM
โOct-07-2016 07:05 AM
โOct-06-2016 05:24 PM
Sprig wrote:dougrainer wrote:
...This also happens to HWH jacks under warranty?...
If it failed under warranty, then I'd figure it was built improperly and let HWH pair for the repair.
I have Power Gear level jacks on my RV. I've had each one of them stick at some point in time over the last 10 years I've owned it.
My jacks get progressively quicker to retract with more frequent use, and slower when stationary for periods of time.
Sometimes inexpensive patch-job repairs can outlast the life of the vehicle.
โOct-06-2016 03:59 PM
bmwbob wrote:
Guys,
I was just asking for some help. It was not my intent to start a war!
Please note: ALL I did to get my sticking jack to function properly was to spray the shaft with some WD40 as several of you had suggested.
I'd did not push,pry, jiggle or pound it. In fact, I did NOTHING else other than to push the "Store" button on the control panel.
At this point, while the symptoms may indicate to someone more knowledgeable that other action may be required down the road, I, as a layman can only say that it wasn't working, and now it is.
Bob
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โOct-06-2016 02:57 PM
โOct-06-2016 01:58 PM
Sprig wrote:
How much $$$ for a new jack?
How much $ for some lube?
I'll keep applying a lubricant 'till the lubricant does not allow it to retract.
โOct-06-2016 01:56 PM
โOct-06-2016 01:31 PM
โOct-06-2016 12:59 PM
โOct-06-2016 10:23 AM
โOct-06-2016 08:09 AM
PursuitInsight wrote:
sorry about this. i related my experience, first hand and this was 3 weeks ago that i replaced the oil. i only wanted to help and have no explanation but the result was that 1 year of 2x4 and a wood block (still in the motorhome) action is no longer required.
i experienced it, you know better
Yves
edit: brake fluid is contaminated by rubber deterioring and not moisture
it becomes black with hose particules
โOct-06-2016 05:43 AM
โOct-05-2016 06:22 PM
