โJan-31-2015 09:30 AM
Hope always rises when needed.......
โFeb-14-2015 06:57 PM
โFeb-14-2015 03:48 PM
โFeb-02-2015 06:31 AM
gfbishop wrote:
Instead of purchasing awning locks, I opted for zip ties. Zip ties are a MacGyver necessity!
โFeb-01-2015 07:50 PM
โFeb-01-2015 07:08 AM
โFeb-01-2015 06:08 AM
โJan-31-2015 05:08 PM
โJan-31-2015 02:44 PM
โJan-31-2015 12:24 PM
โJan-31-2015 12:12 PM
โJan-31-2015 11:57 AM
โJan-31-2015 11:12 AM
โJan-31-2015 10:41 AM
Dennis M M wrote:
You should have a rod about 4 feet long somewhere with a 90 degree hook on the end. On the rolled up awning, most likely the right end there will be a lever, usually T shaped. If it is up, flip it down, or vice versa. Then there should be the loop end of a strap hanging down somewhere along the length of the awning, grab that with the hook and pull the awning down. Then you extend the arms on each end to raise the outside of the awning.
The rod could be anywhere, on the floor in the closet, under the couch, in a compartment somewhere, etc.
โJan-31-2015 10:26 AM
