Pad under jacks
S-n-L
Hi all,
Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground?
Has anyone used this brand of pads: http://outriggerpads.com/
If you do use jack pads what size do you use. I am interested for a 45 foot DP.
Thanks
Stuart & Leslie Offer
2008 Holiday Rambler Navigator 45-Caspian IV, Cummins ISX 600. 2014 Jeep Cherokee limited,Cashmere. Roadmaster Sterling, SMI Airforceone. Full timing since June 1, 2014
44 REPLIES 44
msmith1199
bsinmich wrote:
When a CG in Cincinatti told me I had to put pads under my jacks I got a refund and left. I physically can not get down on the ground to position it properly and still get back up. DW has also had 3 knee replacements and should not get down on her knees. (she wore 1 out after 10 years. she really only has 2 legs) When I go to my cousin's place on his alphalt drive he puts the boards down.
You should have explained that to the campground owner and I'm sure they would have come to help you.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Ozarkan
Much to my dismay I discovered that my jacks leave rust marks on my expensive stain finish on my pad in an owner RV resort. Plastic jack pad have stopped this problem. Also camped where my jacks sank into the mud several inches. I had to use a cow bar to pry my jacks free from the mud. Yes I use jack pads.
Warren & Judy
2007 Newmar Kountry Star DP 39'
CANEY
The object of the pads is so that your jacks retract. If the asphalt or mud is soft and your automatic system buries your levelers a foot in the ground, your weak return springs can retrieve them out of a big hole not hindered by crud. It costs big bucks to have a large tow truck lift your RV out of a tiny hole packed with asphalt. Yes it can happen in Wal-Mart!
Dennis & Melody
2004 27 FT HR Savoy
2000 GMC 1/2t Std Cab short box
NOMADS
Goose2448
If we are gonna talk pads, I have been using scaffold board planks. 8"x16" Their about 2" thick as well. Good Oak, and their free, so why not? HAHA
2008 GMC LMM CCLB DRW "Stuff and Things"
2004 Jayco Jayflight
hammer21661
I usually use a 6x8 about 14 to 18" long if I am worried about sinking I place it on a pair of 2x8s or 3x 8s about 14 to 18" inches long. I lay them down next to one another and cross with the 6x8. They will not sink unless you are camping in a marsh. If height isn't an issue I would probably use an 18" 3x10 under each pad two with a cross piece the same dimention if I was worried with your rig. The out rigger pads are pretty expensive aren't they? I also Use a short boat hook about 3 or 4 foot,it works wonders for reaching things.
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
CT_WANDERER
Like J-Rooster I use 2 X 10, but I cut mine at 18" fits my roll out shelf. I always put blocks under my jacks.
d_denver
I use the plastic cutting boards from the .99 store. They even have a handle so you can use your awning stick to place them.
2002 34' Holiday Rambler Pusher
2005 VW Convertible toad
2008 Dodge 4x4 "Power Wagon" toad
J-Rooster
S-n-L, I use 2" X 10" X 8' Douglas Fir wood blocks! I buy the wood at Lowes, and I have them cut them into 2' sections. Lowes does 3 cuts for free, which makes 4-2' boards and no cutting or hauling a long board home! I've used everything and this works the best for me. And they won't wear out in my lifetime. I really like how they work in soft ground and in the heat (where my jack would damage the asphalt) they disperse the weight of my coach and transfer it evenly thru the 2" X 10" board. Good Luck in whatever you choose.
Janss
I have a set of those yellow (or orange) leveling blocks. I use those with my awning stick to maneuver. If one or more of my jacks has a very long way to the ground, I put multiple blocks under it.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
rk911
S-n-L wrote:
Hi all,
Thanks
I made my own from 3/4 plywood roughly 15" square. drilled a hole in one corner and attached a 24" length of cord. when retrieving the pads I just lift the jacks and pull on the cord.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Glor-E-B
I made my own pads from 1" thick white HDPE. Drilled a hole in each one and use the awning grab stick to position & retrieve them. Still gotta get down but don't hafts go under. I made 7 so I can stack a corner if needed.
Goose2448
Always use cribbing. Larger area helps spread the weight. Sure on harder ground you can get away with no cribbing, but when in soft stuff like sand or dirt, its better to overdo it than be on your side.
lanerd
I made mine out of 1" plywood by cutting six pieces 14" square and glueing/screwing two together with the top grain 90 degrees from the other. I then gave them a good soaking in sealer and two coats of white enamel paint. I then drilled a 1" hole in one of the corners so that I can use my awning rod to place and remove them. For those of you who are wondering why only six pieces....I only have three jacks.
I got one of those heavy duty grocery bags that all three fit in nicely and I usually use them when on any surface other than concrete.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
bsinmich
1999 Damon Challenger 310 Ford
rode2nowhere
Lots of people use wood blocks or boards, they make plastic ones I saw on amazon fairly cheap about 2 inches thick and around 8 inches square I may splurge and get them. Up to now I have used nothing and never had a problem.
