Poor water pressure out of shower head
locster
How can I increase the water pressure in my shower head? Whether hooked up to city water supply or via the pump, the output is very weak.
The flow pressure at the other faucets in the coach are fine.
11 REPLIES 11
KristinU
+1 for Oxygenics. To note, I read somwhere that the white ones are more prone to defects/breakage than the chome ones. We've had our chrome one for a couple of years with no problems. Helpful hint: keep the OEM shower head just in case you decide to sell/trade your unit so you can take your Oxygenics with you to your new rig.
Cheers!
Kristin
2008 Winnebago Chalet 31C
My camping party: me, DH, DS, and 2 DK9s
Our Blog: www.winnieadventures.blogspot.com
jamesa403
How about soaking the shower head in CLR for a couple of hours. It will remove all of the calcium buildup in the shower head. You can also use HOT vinegar and water, half and half, and let it take out all the buildup. CLR is a product available in Canada, and I assume also in the US.
cmalberto
Oxygenics shower head - no more problems. DW gave a thumbs up.
Mickey Alberto
2014 Coachmen Leprechaun 320BH
BillyandKris
We had same problem and got the Oxygenics showerhead. It surely does put out more water. HOWEVER, it is very top-heavy and we could not travel with it in the wall bracket. Also could not leave it swinging in shower hitting walls so had to remove it each time we moved. Hassle. Next it started leaking from the bottom part in no time and no way to repair. Got it at Camping World. Receipt is at home. Can't get to CW as we are on the job. Cost more to get it returned than it is worth. Very disappointed; will not buy another one. On our last camper the dealer replaced the showerhead with one that looked just like the one that came in it. However, it had great waterflow. I do not know brand, but plan to find out from the service guy.
tbred
tenbear wrote:
I would try the Oxygenic shower head first, then if you want more water, drill out the reducer.
Here is a link.
Yes, Oxygenics showerhead makes all the difference!!!
tenbear
Here is a link.
2010 Subaru Impreza Sedan
mdamerell
Drilled out the reducer and got an Oxygenic Shower head. Works great!
2012 Sundance 3100RB w/Reese Goose Box
2004 Ford F350 6.0 L PSD, CC, DRW, long bed, B&W drop ball hitch, Firestone Ride-rite air bags.
Old-Biscuit
joe b. wrote:
I had the same problem and found a plastic reducer washer, where the flexible hose attached to the faucet on the wall. Drilled out the hole in the reducer, a small bit at a time, till I got the pressure I wanted. Of course the 6 gallons of hot water doesn't last as long with the higher pressure/volume. But a good trade off, IMHO.
X2
Did the same thing on the one in 5th wheel.
Now that we have a house again......yep, did it to them also.
Big improvement in flow. Dang flow resisters.
bob213
I would do as Fred suggests and then get an Oxygenics shower head. In combination with a "good" (like a Watts) water regulater, you will have a shower like at home.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
joe_b_
joe b.
Stuart Florida
Formerly of Colorado and Alaska
2016 Fleetwood Flair 31 B Class A w/bunks
www.picturetrail.com/jbpacooper
Alaska-Colorado and other Trips posted
"Without challenge, adventure is impossible".
Golden_HVAC
Hi,
Mine had mineral build up at the shower head. It would come out of the tub valve fine, but not the handle. There is a on-off switch on my shower head, I guess it is open all the way. I was able to remove the shower head and clean the little openings on mine. Yet I was still wanting more water. Eventually I replaced the shower head with a 1.4 GPM rated one from Home Depot.
You might also try pushing a pin into each water spraying outlet, and see if it increases the flow.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
