Dec-18-2016 05:46 AM
Dec-18-2016 02:05 PM
Bud
USAF Retired
Pace Arrow
Dec-18-2016 01:48 PM
Dec-18-2016 01:21 PM
Dec-18-2016 12:48 PM
dougrainer wrote:revrick3 wrote:
This is getting pretty confusing now, so many differing ideas. This might be beyond my expertise. Don't want to get electrocuted. Have volt meter and can test volts at switch will attempt this tomorrow. When looking at switch with cover open I don't see any contacts to stick. I am familiar with points sets as I used to put points in auto years ago. Don't see any in switch. Just many wires hooked into lugs. Are points behind this switch?
Current and still an RV Tech for 37 years, SOOO, you can take my advice to the bank. What you are doing is NOT the contac POINTS in the box. You will see heavy duty wires (Black/Red/White/Green, maybe copper instead of green). You will see if the box has screw mounts the RED/BLACK/WHITE in line 3 times. 2 sets on one side and 1 set on the backside of the relays. The 2 sets side by side will be the Genset and Shore Power inputs. You are measuring the White to Black and White to RED on each set. Most Transfers the set will be labeled on a schematic, but for your test we don't care. With Shore Power disconnected and the Genset ON, all you want to do is see if one of those Red/Black/Whites have 120 between the White and Red and the White and Black. IF YOU DO (odds are you will) then the Transfer box is bad and needs replaced. If you have NO 120 power in that transfer box, then the problem is probably the Genset. But, since you are a little confused, get someone else that has more confidence to check the power at the transfer box. Doug
Dec-18-2016 12:19 PM
Dec-18-2016 12:16 PM
Dec-18-2016 12:05 PM
Dec-18-2016 11:42 AM
Dec-18-2016 09:31 AM
rgatijnet1 wrote:
Before I would take the cover off of the transfer switch, I would plug in to shore power again and see if it clicks. If it clicks, the transfer switch is OK.
There is no need to do that again with the generator running.
If the transfer switch does not click when you start the generator, check the circuit breaker on the generator itself. These may be difficult to find on some generators but it should be on the front side. Try resetting the circuit breaker and see if that fixes your problem. If not, it may be time to contact someone to service your generator.
Dec-18-2016 08:09 AM
Dec-18-2016 07:13 AM
rgatijnet1 wrote:pianotuna wrote:
Hi,
Just because it clicks does not mean it doesn't have burned contacts on the generator side. I dislike transfer switches.rgatijnet1 wrote:
If the power is transferring on shore power when it clicks, then the power will transfer on generator, if the generator has output. It is the same contacts on the output.
Dec-18-2016 06:55 AM
pianotuna wrote:
Hi,
Dec-18-2016 06:53 AM
Dec-18-2016 06:49 AM
revrick3 wrote:
Checked all breakers and ok. I made mistake about bumping converter, I meant transfer switch. Pulled off cover and all looks okay. When on shore power it hums and clicks when cutting on power. When cutting on genny nothing, no click or hum. How can I tell if the switch is bad or if genny not sending power to switch>
