Jan-07-2017 11:04 PM
Jan-13-2017 10:26 AM
Jan-12-2017 04:35 PM
j-d wrote:JaxDad wrote:
Again, this is clearly NOT the issue here.
The OP previously said;
"...when I tried to light the stove top burners, they would not light either....
Most likely true! I wanted to confirm that the Low Battery thing can happen, and probably not all that uncommon. Another could be the Sail Switch was sticking.
I've read of cases where a Fiver wouldn't keep a Generator running because the LPG flow was chilling the tank to where no more vapor was available.
Jan-12-2017 06:53 AM
Jan-12-2017 04:27 AM
j-d wrote:miniwinipowerstroke wrote:
You didn't run out of propane but you did run out of sufficient power (battery current) to light the electronic ignition in the furnace.
Something like this happened to us in Alaska. Woke up in the middle of the night to the furnace turning on and off, and the LPG alarm sounding then quieting. The battery wasn't good enough to keep the furnace running. It'd stop then lose a little LPG when trying to re-light, setting the alarm off. About then the battery had rebounded enough to run the furnace again for a few minutes.
Do notice: I said "not good enough" and we in fact replaced the battery after that trip. This coach is a 36-ft Jayco fiver. Equipped with one battery, not sure there was space for another.
Jan-11-2017 02:42 PM
Jan-11-2017 01:49 PM
Jan-11-2017 01:16 PM
Jan-09-2017 03:46 AM
Jan-09-2017 03:41 AM
Old-Biscuit wrote:
Your LP Regulator is NOT providing correct system pressure which is 11" WC .
Jan-08-2017 06:09 PM
gja1000 wrote:
Old Biscuit, would the RV dealer check the LP pressure or would I take it to an LP place to have the pressure checked?
Jan-08-2017 05:41 PM
Jan-08-2017 07:31 AM
Jan-08-2017 06:18 AM
Jan-08-2017 05:31 AM
