"8 D Battery" Anyone ever use one for house batt?
FIRE_UP
Gents,
Well, our Costco, 6V golf cart batteries (dated 8-11) just passed the 4 year old point and, based on a few things, I'm not sure they're holding up their end of the bargain for keeping charged and holding it. Now, I've been a pretty good one for maintenance and all that for most of my RVing life. But, I will admit, I've grown a bit complacent when it comes to my RVs batteries. It's one of those things, "out of sight-out of mind" things.
More than once, I've decided to check on them to see how things are and, I open the bay door where they're stored and, it looks like I'm cultivating GREEN FUZZ/CABBAGE at many of the terminals, YUCK!!!
It takes me a good hour or two to remove, clean every thing, including cables, cable ends and all that. Not to mention, that's very tedious job to do because if you get any of that on your cloths, you all know what it does. And, I've had to fill them several times when doing this process. In a couple of cases, they were down to around 11 volts or so.
And I don't want to hear about those multi-fill or, Auto fill gadgets because, THEY WON'T FIT. I've got right at 1/8 of an inch in clearance of the bay door frame when those batteries are slid out and back in, in their tray.
But, I always babied them back to life and, used them on trips. But, lately, it seems as though they don't have the STAMINA that they did when they were new. I hate running the generator in quite camp grounds just because I'm allowed to. But, sometimes their down to 12.0 in what seems a short time of using them. And that simply entails the use of a TV and DVD player for maybe, an hour or so. Sometimes they're higher after that time frame and, sometimes they're at that low voltage.
So, this brings me to now. I'm considering a few options here.
1. Just buy new 6V ones (4 of them at a local cost of $140.00 each plus tax)
2. Since we do mainly "hookup" camping about 60% of the time and, dry camping the rest, I might go back to 12 units 'cause that's what was in there when we purchased it four years ago. Not sure of that option yet.
And 3, I'm thinking, JUST THINKING at this point, about maybe going to an 8D battery for a single house battery. Those things have around 1150 CCA. Now, I know, nobody cares about CCA in house batteries. But, when I asked the Interstate Salesman about ampere hour capacity, which is what many Golf cart and RV house batteries are rated at, he didn't know.
I also know that, it would be the ONE and only battery while, if I kept the (4) 6 volt operation, if one went bad, I could just replace the one. Or, the same with a (3) 12V Deep cycle Marine setup.
But, I can't help thinking that you'd get this monsterous amount of time on an 8D before you'd need a re-charge. What say all you battery wizards out there in RV land???
Scott
Scott and Karla
SDFD RETIRED
KI60ND
39 REPLIES 39
pianotuna
Nomad III
Nomad III
Group 31 agm will be an acid starved battery. It makes it a bit more important to follow charging recommendations to the letter. Temperature compensated charging is a good plan with such a jar. Getting back to 100% promptly is a good thing with all lead acid chemistries but again is just a bit more important with a starved acid configuration.
Regards, Don
harold1946
Bear in mind that is not a true deep cycle battery. It is a hybrid deep cycle/starting battery. Not the best choice as a house battery.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
FIRE_UP
cbeierl wrote:
Scott, I ended up going with 3 of these Duracellยฎ AGM Deep Cycle Marine and RV Battery - Group Size 31 from Sam's Club. The primary reason I decided to go AGM was to eliminate the corrosion issues. Not having to worry about the water level was also a big plus.
OnEdit: Fixing link
Chris,
As usual, your knowledge and expertise are incredibly valuable to me. I will look into those, even though, at present, we're not members of Sams Club. We do have one about a little over an hour from us in Bullhead City AZ. Thank you very much.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
cbeierl
OnEdit: Fixing link
Chris Beierl
2005 Winnebago Vectra 36RD
harold1946
chuckbear wrote:
harold1946 wrote:
chuckbear wrote:
Compare the weight of one 8D battery to your 4 6volts. Also look at the cost of one 8D quality deep cycle battery compared to your 6volts. Your 4 batteries that you have now are double the amp hours of a single 8D. For running the coach, your main concern is amp hours and not cranking amps. Once you do the comparisons, your answer should be simple. Chuck
Not sure what you are comparing but.
Top of the line GC2s 6 volts are 225 AH each. 2= 225 AH. 4= 450 AH.
Top of the line 8D 12 volts are 290 AH each. 2 = 580 AH
Forget the cost and weight, its like comparing a VW to a RR.
harold, I beleive he said he is replacing 4 6volts with one 8D. Chuck
OOPS; I need to read more carefully, thanks ๐Ÿ˜ฎ
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
2oldman
Kayteg1 wrote:
Is carrying newly wed bride into the house still common?my wife was about 100lb at the time, but I wonder how many today's brides are 163 lb or more?
That's funny. ๐Ÿ™‚
chuckbear
harold1946
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
Kayteg1
My wife was about 100lb at the time, but I wonder how many today's brides are 163 lb or more?
Coming to AGM batteries, I think this is one of the cases where marketing overcome common sense.
They do have some advantage, but not much apply to RV application.
Read Wikipedia
Comparison with flooded leadโ€“acid cells[edit]
VRLA batteries offer several advantages compared with standard lead-acid batteries. The battery can be mounted in any position, since the valves only operate on overpressure faults. Since the battery system is designed to be recombinant and eliminate the emission of gases on overcharge, room ventilation requirements are reduced and no acid fume is emitted during normal operation. The volume of free electrolyte that could be released on damage to the case or venting is very small. There is no need (nor possibility) to check the level of electrolyte or to top up water lost due to electrolysis, reducing inspection and maintenance.[8]
Because of calcium added to its plates to reduce water loss, a sealed battery recharges much quicker than a flooded lead acid battery.[9][10] "From a standard car, 4WD or truck alternator they will recharge quickly from full use in about 2 to 3 hours. A deep cycle wet cell battery can take 8-12 hours to achieve only 70% to 80% of its potential charge."[11] Compared to flooded batteries, VRLA batteries are more vulnerable to thermal run-away during abusive charging.[1] The electrolyte cannot be tested by hydrometer to diagnose improper charging, which can reduce battery life.[10][12]
AGM automobile batteries are typically about twice the price of flooded-cell batteries in a given BCI size group; gel batteries as much as five times greater. VRLA batteries:
Have shorter recharge time than flooded lead-acid.[13]
Cannot tolerate overcharging: overcharging leads to premature failure.[13]
Have shorter useful life, compared to properly maintained wet-cell battery.[13]
Discharge significantly less hydrogen gas.[13]
AGM batteries are by nature, safer for the environment, and safer to use.
Can be used or positioned in any orientation.
Peralko
Our coach came with 2 8-D chassis batteries and 2 8-D coach batteries on slide-out trays. Replaced the coach batteries seven years ago with AGM--they are doing fine, and don't corrode at all. Replaced the 13-year old chassis batteries with Sam's Club wet-cells two months ago. The 163-pound weight is not as bad as it sounds, plus the slide-out tray made the change-out easier. Harder to put the old batteries back in the bed of the truck!
Peralko
USAF Retired
2000 Prevost Marathon H3-45
2006 Nissan Maxima
tplife
2oldman wrote:
Kayteg1 wrote:
Is he getting his money worth comparing to $48 I spend?
Value is different for each of us. AGM value is in zero maintenance, and virtually no corrosion. I have the money, I'll spend it on convenience. Price is a pretty narrow definition of 'money's worth.'
The extra money I spent on an Optima Blue-Top AGM battery was well spent, and it included a large number of advantages like no degas (safe to mount indoors), deeper discharge without damage, (see FullMosey abvove) etc. etc. too many to list here. I'd go AGM again in a heartbeat for any application where I can afford the extra cost - I'll get it back.
full_mosey
Go to a club store like Costco or Sams and get the cheapest 4 x 6V GC batteries. ๐Ÿ™‚
Then use some of your spare time to get the real skinny on AGMs.
Last year I advised a fellow camper to replace his 4 x 6V GCs with only 3 x 100AH AGMs from Sams Club. Yes, 440AH replaced by 300AH! He dry-camps mostly. Yes, we are still good friends! ๐Ÿ™‚
In fact, last week he had a lot of praise on how well 300AH of AGMs kicked 440AH of GCs butt on both drawdown and especially recharge.
Please look at my profile. I run 2 x 12V compressor fridges from a single 100AH AGM. Not only that, in the morning I can draw 700W for 30 minutes to make coffee and breakfast for me and the wife. I do have a Panasonic MW, a 700W Mr. Coffee and an induction stovetop that were specially bought for that use. Remember, breakfast comes after running the fridges overnight. AGMs hold Volts so you don't trip your inverter.
Recharging is with a Magnum 1012 inverter/charger 1000W/50A. Yes, the charger is 50% of the battery's AH. Try that with your flooded battery. AGMs suck up AMPs and charge faster while using less genny fuel.
That's my report and it is real, not some vague un-reference to 'some reports'.
HTH;
John
dons2346
"However, a severe bad point is, ONE HUNDRED AND SIXTY SEVEN POUNDS, in ONE battery. Yeowwwww!! It would be ME ONLY that would have to get that in there. Now, I can pick up 167 lbs. Not a problem. But, based on the logistics of the slide out battery tray, the angle of the semi-open bay door, the height of the tray to the ground (approximately) 30" or so, what ever kind of handles are on that particular battery, I think I'd kill myself trying to get it in there. "
My battery tray isn't that high and no way could I pick up 160. I used a transmission jack to get them out of the truck bed and into the coach. Piece of cake
Ductape
Do the equalizing and check SG before spending any money. GC's can take a lot of abuse.
Sounds like in your case you must remove them for SG testing or to add water because of limited clearance? Advantage AGM.
49 States, 6 Provinces, 2 Territories...
