Jun-15-2014 07:10 AM
Jun-16-2014 03:53 PM
Jun-16-2014 02:23 PM
Jun-16-2014 01:54 PM
dshinnick wrote:
What really confuses me is that it leaks even with the slide in. And when it is in, the seals all the way around look pretty darned good. At least to my novice eyes.
Jun-16-2014 11:53 AM
dougrainer wrote:I took Doug's advice a long time ago when I had a leaky slide out seal and had a shop do it!
1. NONE of the previous 4 shops determined it was a defective slide seal causing your problem?
2. You have NO experience, but have determined you need the slide seal replaced?
3. I would hesitate to trust a Mobile Tech to fix your problem if 4 other shops have not determined the problem.
4. Is the Slide cover in good repair and the slide cover "mount" track secured and sealed to the sidewall/roll wrap? If the slide cover leaks on Monaco produsts that contributes to a slide leak. Monaco's require the slide cover to be in good repair to prevent excess water from flowing thru onto the slide room roof.
5. If you have a slide cover, then it must be removed to do the seal replacement. IF the slide fabric is in bad condition, then have the slide fabric replaced at the same time to minimize the labor costs.
6. DO NOT remove anything, Let the Tech do that so he has an idea of what the problem might be. If you came to me and stated you wanted the slide seal replaced and it was there or you removed, I would replace it and THEN, if you still had a leak, YOU would still be on the hook labor and part for what the real problem is.
7. You should be able to look on top the top under the slide cover or inside to see if the seal has come loose from the long top mount. Have someone operate the room while watching and you will see if the seal rolls loose somewhere along that mount. Doug
Jun-16-2014 10:46 AM
Jun-16-2014 09:18 AM
Jun-16-2014 07:27 AM
gatorcq wrote:
Yes you can do it your self, especially if you are only doing the outside.
Normally there are 2 seals, 1 on the slide itself and the other on the outside rail.
Use NAPA brake fluid to clean off the adhesive residual. I also used a Harbor Freight vibrating tool to remove the old seal.
I first locked my awning in place, then remove it and placed it on the roof of the RV. Once you are ready, all you have to do is remove the paper backing and press the seal in place.
In the corners you can use screws to hold in place. Please do not let people scare you from doing a easy job. It is all about the prep work and cleaning.
The bedroom slide took me 3 hours. The large living room slide I got it down to 2 hours.
Jun-16-2014 06:20 AM
Jun-16-2014 03:55 AM
CleoBevacqua wrote:Looks like someone couldn't sleep.
The activity of the animal beings,,,
Jun-15-2014 03:17 PM
Jun-15-2014 12:37 PM
Jun-15-2014 11:28 AM
Jun-15-2014 10:50 AM
Jun-15-2014 08:33 AM
