โFeb-16-2014 12:40 PM
โFeb-26-2014 08:04 AM
โFeb-26-2014 07:04 AM
riven1950 wrote:
Thanks for the video and info. Now know I need roof vents and would like roof vent covers.
My TT is an o7. The roof vents ( moving part ) obviously need replacing. The bases the roof vents attach to appear ok and are sealed good to the roof. Do the bases normally last a lot longer than the moving roof vents?
BTW: I apologize for taking over the thread.
โFeb-26-2014 06:28 AM
โFeb-26-2014 06:07 AM
โFeb-25-2014 06:35 PM
โFeb-25-2014 04:39 PM
โFeb-25-2014 03:29 PM
j-d wrote:
They come with four aluminum angle brackets. The short edge of the brackets fasten to the vertical part of your roof vent flange. The long edge hugs the roof surface and the vent cover fastens there.
So installation is drilling four small holes in each flange then assembling the brackets and dropping the cover down onto the brackets and applying a nut.
NO penetration of the roof fiberglass or rubber sheet.
โFeb-25-2014 03:02 PM
โFeb-25-2014 01:20 PM
โFeb-25-2014 06:18 AM
riven1950 wrote:
Bobbo, I need to replace two vent covers on mt TT. I like the looks of the Aero flo unit. Live on the coast and have a lot of wind, is there any way water can be blown in these units when fully closed..it looks like they have vent holes around the side in addition to opening at top?
There are no openings on top. The openings are all on the sides and back. It would take a hurricane to blow water in. The water has to be moving sideways and upwards.
I think my bases are ok. Would these units mount on a standard size roof vent base?
Yes, they are designed to cover a standard vent.
One of my vents has a switch operated fan in it ( which we have never used ). Do they make one of these with a fan in it?
No. These are not vents. They are vent COVERS. You install your vent, the one that opens and closes and maybe has a fan in it, then you install this vent cover over the vent. These allow you to keep the vent open during bad weather.
Sorry for all the questions, Camco website not clear. Just thought you or someone might know. No Rv places close by. Will have to order or make a trip of 30 miles one way to check them out.
โFeb-25-2014 05:36 AM
โFeb-18-2014 09:50 PM
โFeb-18-2014 09:23 AM
โFeb-17-2014 06:50 PM
