โMay-14-2017 09:38 AM
โMay-17-2017 04:01 PM
โMay-17-2017 03:51 PM
โMay-17-2017 03:21 PM
โMay-17-2017 03:06 PM
โMay-17-2017 01:05 PM
โMay-17-2017 12:07 PM
RDG wrote:
Does anyone here vent their HOME residential fridge to the out side? I doubt anyone here does, so why the big issue with the residential fridge in the motorhome? I changed over to a residential unit and have never felt any amount of heat coming from under the unit or off the top.
Bob
โMay-15-2017 03:17 PM
bluwtr49 wrote:
My Samsung is front intake and front exhaust. There is a baffle in the rear that separates the inlet and exhaust with an access plate covering the two. That's why I thought about removing the plate and cutting it so it only seals the inlet and air from the fan would still cool the condenser but let it exhaust out the back and up the sidewall to the roof top vent. Since it would be a positive pressure not additional fan would be necessary.
Of course I could be fixing a non-exsitant problem,...I've been known to do that occasionally.
โMay-15-2017 11:28 AM
โMay-15-2017 06:15 AM
โMay-15-2017 06:00 AM
No, but my RV residential fridge is essentially in an enclosed cabinet with its back against a thinly insulated wall that can be exposed to direct sunlight and potentially high temps.
I monitor my Whirlpool's freezer and fridge temps pretty closely. During a month I was in a southern campground, I noticed a consistent temp rise during the day as the sunlight hit the fridge side of my RV. The Whirlpool manual suggests the fridge works best in an environment between 60 - 90 degrees F and also warns against installing next to a heat source.
Anyway, after I added the roof fans, the temp variation seems to have stopped.
While I'm fairly confident that my Whirlpool would continue working without the roof fans, I can't deny the temp decrease I saw, and I believe the increased ventilation may lengthen the life of my residential.
โMay-14-2017 09:15 PM
โMay-14-2017 05:29 PM
โMay-14-2017 05:05 PM
โMay-14-2017 04:17 PM
