roof air
choppermtn
I need to replace my roof air . I have replaced one before but this one is ducted and has no access from the inside of coach How do I remove the roof unit to replace it?
19 REPLIES 19
oldave
wrgrs50s wrote:
Doug, your response to this gentleman was very rude. He simply stated he had never seen this type of installation, as I have not either. We are all on this site for learning not for unwarranted sarcasm.
Well I'm not the first or only.
I don't care to be offended that easily more important things
in my life .
Btw I don't remember stating I am a layman
Ray
dougrainer
wrgrs50s wrote:
oldave wrote:
dougrainer wrote:
When you state you have never seen that design. WHAT is your qualification to state that? THAT design has been on Newmar's for over 25 years. Airstream uses a similar mount. Tiffin has used that type mount for almost 15 years. Jayco uses that type mount(top down) used that type on some of their models. ANY RV unit that has NO 14 inch square inside duct cover access will have top mounted system. That pic is on top the roof. Doug
WHAT is my qualification ?
Well how simply can I say it ?
All of my RVs so far have been the kind that bolt from
below and I haven't gone around asking other people
how does you air cond bolt to your roof .
Ray
I asked the question because there are a LOT of so called Mobile RV Techs and even Service center techs on these forums that think they know everything. From his statement, I wanted to know his expertise. He stated he is a layman. My question was NOT rude. It asked a specific question and he responded. As I stated, there are NUMEROUS OEM's that use the top down bolt/lag method. IF you go to a Service Tech and he states he has never seen a top down method, then do not let him do the job. ALWAYS ask if they have done such a job before. I have repaired numerous Newmars/Airstreams and Tiffins over the years after a unskilled so called Tech did not install the separator between the intake and exhaust on top bolted AC units. Doug
Two_Jayhawks
dougrainer wrote:
Two Jayhawks wrote:
choppermtn wrote:
Thanks everyone for the info
Also, my lag bolt heads are covered in silicone requiring removing silicone to remove lag bolts. Since it came that way from Newmar I reinstalled new silicone after tightening bolts.
Yes, you can do that. What I do is, after installing the lag bolts, I remove and inject silicone into the hole then reinstall the Lag bolts. There is no need to install Silicone over the top of the bolt when you do this. Doug
I like your method better. I've had to go up & re tighten my bolts but didn't remove them. Removing bolt & squirting silicone in the hole would also maybe keep me from having to re tighten down the road. :S
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
wrgrs50s
Ray
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
oldave
Ray
dougrainer
Two_Jayhawks
Bill & Kelli
dougrainer
oldave wrote:
dougrainer wrote:
Chris Bryant wrote:
Yours is going to take a very specific replacement, depending on what you have. It is lag screwed in, instead of bolts. Here is a picture from one of the training power points showing a Newmar install.
NOTICE that gasket that goes between the 2 roof holes. THAT gasket is critical for correct operation. It separates the Intake hot air from the cold exhaust air and if not installed or installed incorrectly, you will not get adequate cold air output. The Lag bolts are installed into a wood/aluminum backer plate. Just make sure you measure and drill the 4 holes in the New AC mount pan, exactly where the original ones were, Do NOT over tighten the lag bolts or you can strip them out of the Aluminum plate. Doug
Something new to me , never seen that design .
Those lag bolts , are they from the roof or from inside the coach .
Drilling holes in the new a/c pan sounds like from roof
Couldn't tell for sure from the picture .
oldave
choppermtn
dougrainer
Chris_Bryant
-- Chris Bryant
choppermtn
I have a 38ft. Newmar Mountain Air , ford chassis , v10.Dometic a/c now .
I think I saw the 4 bolts that you are referring to I just don't know if when they are removed anything will "fall" between the roof and ceiling making It near impossible to install the new unit . Are there any "tricks" anyone could share ?
oldave
choppermtn , you should give some info so someone can know what you
are working on . Tell us what brand of coach , year , make of a/c etc
You may even find a picture on line we could look at
What you described does not sound like most coaches or at least like
anything I have seen .
