Apr-30-2013 10:07 AM
May-01-2013 12:19 PM
HappyKayakers wrote:Rich D. wrote:
While I agree wholeheartedly with the posts recommending a full time protection device, the OP asked about checking the power before plugging in. The devices mentioned will protect from many power problems but a suspect outlet should be tested before even plugging in your protection device.
You're absolutely right. My PI unit does check the pedestal before supplying power to the RV. If there's a problem, it will display the appropriate error code so I can tell the office what's wrong. I consider ANY outlet suspect until I've tested it.
May-01-2013 10:55 AM
May-01-2013 08:14 AM
May-01-2013 05:19 AM
May-01-2013 04:45 AM
May-01-2013 04:16 AM
dave17352 wrote:
So do you have to use either a 30 amp or 50 amp surge protector. Do you have to have both. Some parks only have 30 amps. Or do you just use a 30 amp adapter to the power pole if you have a 50 amp service.
Apr-30-2013 09:45 PM
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) 🙂Apr-30-2013 08:57 PM
Apr-30-2013 06:02 PM
Figment II
(2002 Alpine 36 MDDS) 🙂Apr-30-2013 02:28 PM
Apr-30-2013 02:24 PM
Apr-30-2013 12:42 PM
Apr-30-2013 11:09 AM
Even if the post tests good before you plug in, conditions can change. That's why I use a portable unit from PI all the time.
Apr-30-2013 10:34 AM
