Scratches in fiberglass
deewhite0612
Got a bum steer from GPS yesterday and we have a lot of superficial scratches from tree branches on the side wall of our motorhome. Can anyone recommend something that we can use to buff the scratches out?
Michael and Daryl (Dee)
2006 Newmar Kountry Star 3778
2008 Saturn Vue XR V6
Blue Ox Alladin
Brake Buddy Classic
15 REPLIES 15
Gjac
If you look at how your fiber glass front or rear cap is made, Gel coat is applied to the mold first then Fiber glass reinforcement during the manufacturing process. The gel coat is pure resin the FG reinforcement is FG and resin. Clear coat is sprayed on after the MH is assembled and is to protect the paint and make it shine. Not all MH's have clear coat. Some older ones like mine only have gel coat on the front and rear caps not on the flat sides. If you can see a random FG pattern on the outside there is no gel coat. If it is completely sooth it is gel coated. The products mentioned above are safe to use on your exterior.
sidney
I have some light scratches on our 5er.
What's the difference between Gel Coat and Clear Coat?
Our 5er is not a painted exterior. Forest River describes it as: โ€œTrueโ€ Pearl Gelcoat Exterior. The products mentioned in the previous posts are described as safe for Clear Coat. Are they safe for Gel Coat as well?
timmac
TechWriter wrote:
ScratchX
Yes that's good stuff, took the scratches off my motorhome..
J-Rooster
TechWriter wrote:
ScratchX
X-2, This worked for me on my wife's car in the past!
wolfe10
One if the issues here is we really don't know what you are buffing.
Your title is "Scratches in Fiberglass".
But, you mention clear coat.
Is this gel coated fiberglass, a painted surface with clear coat, etc.
This is important, as gel coat is many times as thick as paint and can stand a lot more sanding, buffing, etc.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Bruce_Brown
Moderator
Moderator
If you're in northern NY stop by and I'll buff it out for you, assuming it can be buffed. Serious offer too.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
TechWriter
ScratchX
www.rvSeniorMoments.com
DISH TV for RVs
randallb
Use a brand name "polish" and follow with a coat of wax.
Randy
wrgrs50s
I use this product (Kit Scratch out). It works well and is very reasonably priced on amazon.com or can be purchased at most automotive parts supply.
Click here
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
wildmanbaker
A lot of times, what appears to be scratches, is actually material rubbed onto the paint by the branches. I have found the just using a good clear/wax can remove most of the marks from the side. We use to take our MH down some narrow roads to get the camping spots we wanted. We actually got more scratches from moving things around the MH then when camping. We have used "Nu Finish Scratch Doctor" to remove any actual scratches.
Wildmanbaker
harold1946
deewhite0612 wrote:
i am afraid polishing compound will scratch the clear coat on the RV.
Polishing compoundnot rubbing compound. Two different things.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
deewhite0612
Blue Ox Alladin
Brake Buddy Classic
harold1946
Polishing compound. Available at most auto parts stores and Walmart.
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
cpmath
What do you mean your GPS gave you a bum steer?
